Looking for advice for rounded corner frames - Router Forums
 3Likes
post #1 of 12 (permalink) Old 06-26-2016, 08:37 PM Thread Starter
Default Looking for advice for rounded corner frames
Hello,
I have a small shop in my garage and am struggling on building on a rounded cabinet. I am a novice woodworker and am looking for advice about building rounded corner cabinets. This is the first time I’ve tried to build a rounded cabinet. Not sure if I am doing this correctly, but am a giving it a go. If my terminology is incorrect, or if I need to post to another forum, please forgive me as a am just learning.
I have the built the carcass out of ¾” plywood. I have the pieces cut to length, and pocket holed into the face frame. The face frame is assembled, and a am trying to assemble the rounded corners. I have the bottom attached on the right and left side. The Right side is giving me problems as the rounded moldings are spitting and or cracking.
I have am running into a few problems as the rounded molding keeps spiting and cracking. I cannot figure out to fix the issue or continue with ruining the cabinet.
If anyone has any suggestions or advice, it would be greatly appreciated.
Thank you,
Tom
Name:	Top of Rounded Corner v0.JPG
Name:	Midde 2 Transition Piece-Left Side v0.JPG
Name:	Midde 1 Transition Piece-Spit Right Side v0.JPG
Name:	Midde 1 Transition Piece-Left Side v0.JPG
Name:	Bottom of Rounded Corner Left Side v0.JPG
Name:	Bottom of Rounded Corner-Tearout Right Side v0.JPG
Name:	Example cabinet v1.0.jpg
firstmuller likes this.
perseus7717 is offline
post #2 of 12 (permalink) Old 06-26-2016, 08:49 PM
JOAT's Avatar
First Name: Theo
Not 100% sure what's going on here. You using screws, or nails, to hold those pieces, and there is splitting because of that? I don't make things like that usually, but when, I do I only use glue, no nails or screws. But not to worry, if that's not it, one of the guys who makes furniture on a regular basis will come along, and should give you a answer.
JOAT is offline
post #3 of 12 (permalink) Old 06-26-2016, 09:08 PM
I agree on the glue. Can't quite make out the grain on the rounded pieces, but if you have pocket holes going in with the grain, that could cause splitting. You must pre drill that kind of joint on that grain or risk splitting. Glue will hold those shapes forever, although clamping could be a challenge.
post #4 of 12 (permalink) Old 06-26-2016, 09:14 PM
Tom..
what are your fastening methods???
why are you doing this in sections.....
rip a piece ½-¾'' (or more if you can) ply the width and length of the assembled corner piece...
careful on the fit..
glue the sections to the ply.. use a 23GA pinner to pin the ply to the molding but no larger...
glue the assembly to the face frames and mechanically fasten through the back w/ screws being careful to screw into the ply only..
add blocks to add to thickness for the screws if you can...
the splits are because of the early or spring wood of the pieces...
and it doesn't tolerate mechanical fastening w/o preventive measures...
Early wood or Spring wood
1. Formed during spring season.
2. Formed early in a year.
3. Consists of xylem tissues with wider vessels.
4. Produced more in amount.
5. Less dense.
6. A broad zone of wood.
7. Not as strong as late wood.
Late wood or Autumn wood
1. Formed during winter season.
2. Formed after the early wood.
3. Consists of xylem elements with narrow vessels.
4. Produced less in amount.
5. More dense.
6. A narrow zone of wood.
7. Stronger than early wood due to larger volume of wall materials.
post #5 of 12 (permalink) Old 06-26-2016, 10:05 PM
Tom..
Tom all of that is true. What is cracking your wood is too much stress being put on it. I fully agree with Stick when he says to bridge the corner with ply and then attach the round piece to the ply. Let the ply handle the stress. It's better suited for the job. One of the other possibilities is that the wood may have started with too much moisture content and has dried since you started. Even if that isn't the cause now, it could be the cause of a later failure. Wood cells build up from the center of a tree in layers. Each layer of cells is longer than the previous one so that the outer layers shrink more when it dries than the inner layers. This will cause cracks and breaks if not allowed to move freely.
If you do like Stick suggests I would only attach the piece at its center but it could be attached very firmly if only there. That would allow movement at either end without causing the piece to crack. I personally would try to either rabbet or mortise the ends of your corner pieces into either side at least 1/8". That way if there is shrinkage there won't be a visible gap at the ends where they meet the sides.
post #6 of 12 (permalink) Old 06-27-2016, 07:43 AM Thread Starter
Thank you everyone for all the information on the post!
The wood is Alder. The fastener system is the pocket hole system (Kreg).
The fastener system is indeed a problem here! I used the pocket hole system because I couldn't figure out how to clamp the face frame. Even with 1-2 pocket holes pre-drilled and glue, I could not get the alignment perfect (or at all). My method was to use my figures and hold the rounded pieces into the face frame... Not ideal at all, but I couldn't figure how to hold, clamp, align, glue the pieces, hence the post here :-)
Definitely, I need help with the system that will hold, clamp, align, glue the pieces.
Thanks!
Tom
post #7 of 12 (permalink) Old 06-27-2016, 07:59 AM Thread Starter
Hi Stick,
"why are you doing this in sections....."
The section are purely decoration. See example below.
Thanks!
Tom
Name:	example of molding v0.jpg
post #8 of 12 (permalink) Old 06-27-2016, 10:26 AM
Thanks!
Tom
masking tape and a 23 gauge pinner...
DaninVan and MEBCWD like this.
post #9 of 12 (permalink) Old 06-27-2016, 11:13 AM
And GLUE, Stick, and glue.
DaninVan is offline
post #10 of 12 (permalink) Old 06-27-2016, 11:16 AM
covered that already Dan...
try to keep up...
Floating Corner Shelf JIMMIEM Tools and Woodworking 16 01-07-2015 07:50 AM
Picture Frames Part 2 dmc_md General Routing 12 02-27-2011 09:43 PM
Making picture frames dmc_md General Routing 9 02-10-2011 07:51 PM
Reference to a corner cubbard Bob-O-Link New Member Introductions 2 09-14-2010 11:44 PM
Corner Radius bobj3 Tools and Woodworking 25 09-29-2007 05:51 PM
