Ultimate Workbench - Router Forums
 16Likes
post #1 of 14 (permalink) Old 07-16-2016, 02:17 PM Thread Starter
MT Stringer's Avatar
Default Ultimate Workbench
Looks pretty interesting to me.
I found this project on our sister site Lumberjocks.com.
Ultimate Workstation - by RogueEngineer @ LumberJocks.com ~ woodworking community
I think this could be a good replacement for my work bench. Even though I love my bench, there is always room for improvement.
The poster provided a link to his website for detailed plans and instructions.
MT Stringer is online now
post #2 of 14 (permalink) Old 07-16-2016, 04:40 PM
That's quite a workbench, a lot of thought went into the design and construction, great for someone that has a lot of room to work with. I'd wind up using the TS to cut all the parts out and then have to get rid of it, and the dust collector too probably, to make room for it when assembled. I do like the "shelf" area under the working top as a place to put the tools you're currently using, keeping them handy but out of the way. I've always thought that a bench that wide winds up with a small area on one side where you're working and a bunch of stuff just piled up on the other side. My adjustable bench at 36" x 30" has worked out pretty well so far - if I need a larger assembly area, I could put a sheet of plywood on top of the cutting grid I use with the track saw to break down sheets of plywood.
MT Stringer likes this.
tomp913 is offline
post #3 of 14 (permalink) Old 07-16-2016, 05:22 PM Thread Starter
I think I would have to redo the plans and downsize it to about 32 x 60... or maybe just 48 on the length. I am cramped for room.
Another factor is my uneven floor. It isn't smooth and has high and low spots all over. I believe casters would not work. I would have to resort to the adjustable feet I have incorporated into my current table. Once in place, it would stay there. Probably no access to the back side. Still gives me some inspiration to consider.
DaninVan likes this.
post #4 of 14 (permalink) Old 07-16-2016, 10:54 PM
vindaloo's Avatar
First Name: Angie
Originally Posted by MT Stringer View Post
I think I would have to redo the plans and downsize it to about 32 x 60... or maybe just 48 on the length. I am cramped for room...........
You and me both. That would fill the only available space I have left.
When everything around you is going to pot, get out in the workshop.
vindaloo is offline
post #5 of 14 (permalink) Old 07-16-2016, 11:03 PM
RainMan 2.0's Avatar
Well thought out workbench . I like how it has room directly underneith the top to place things , then shelving under that .
Dam if I only had more room
Ok ,I never insulate
RainMan 2.0 is online now
post #6 of 14 (permalink) Old 07-17-2016, 08:36 AM
First Name: Richard
More room and insulation?
Shop guy is offline
post #7 of 14 (permalink) Old 07-17-2016, 09:45 AM
First Name: Keith
Has anyone figured out yet what this thing would cost to build?
There's a ton of plywood in that bench...not only expensive, but it's going to take a long time to make, and it's going to be heavy. Of course the heavy part is a good thing with any work bench.
I don't see it as being particularly useful for a full fledged workbench, more like an assembly bench with oodles of storage. I must admit I like that part.
As for space to locate it, like most of you I'm desperately short in that area.
DaninVan and MT Stringer like this.
OK, fess up...which one of you clowns stole my sig? It was right here a second ago.
cocobolo1 is offline
post #8 of 14 (permalink) Old 07-17-2016, 10:27 AM
this work table was all product of dumpster diving and hardware from ripped out kitchen cabs...
might have have 20-25 bucks in it...
Stick486 is offline
post #9 of 14 (permalink) Old 07-17-2016, 02:44 PM
Guest
I'd love to have a table like that but for me, the ideal workbench was one that was sturdy, big enough but did not use up all the available space, light enough to be moved easily, could be used as an an outfeed for the TS, an assembly table, a (too frequent) storage table...and especially one that could be knocked down and stored out of the way when necessary. This was necessitated by a smallish 2-car garage where other people (but not the car) have dibs on some of the space. Oh, and it had to be made entirely from scraps.
163481 is offline
post #10 of 14 (permalink) Old 07-17-2016, 02:57 PM Thread Starter
So...I was out in the shop working on some cutting boards. I got to thinking dam I like this workbench. What in the world was I thinking?
Maybe a new top. Yeah, that's the ticket.
cocobolo1 likes this.
Wired Workbench DonkeyHody DIY and Renovation 13 03-09-2015 05:32 AM
My first Workbench Burke Show N' Tell 11 10-15-2011 10:25 PM
Half Blind Dovetails for a Workbench kbiniowa Tools and Woodworking 5 04-23-2011 08:16 PM
Workbench / Router table Jusaquikie Table-mounted Routing 14 03-15-2011 10:19 AM
Workbench - router table : connection dilemma. matt1710 Table-mounted Routing 22 12-26-2010 02:54 PM
