Presentation - Router Forums
 18Likes
  • 9 Post By Herb Stoops
  • 2 Post By Semipro
  • 1 Post By Stick486
  • 3 Post By vchiarelli
  • 1 Post By RainMan 2.0
  • 2 Post By schnewj
post #1 of 9 (permalink) Old 05-26-2017, 07:15 PM Thread Starter
Default Presentation
Last night I did the presentation at the NWW Workers Assoc. meeting of the Fractual wood burning.
After stressing the safety standpoints thoroughly, I did a slide show of 250+ pictures of my latest projects and then had a drawing for the 20+ items that I made with the Fractual wood burning technique. At the end of the program I showed them the documentation of the fatalities from doing this type of work and stressed the risk involved and the fact of no margin of error. Most members agreed that the risks were not worth the consequences.
At first they were disappointed that I didn't do a hands on demonstration, but I explained that since we were meeting at WoodCraft Store, that I did not feel that I should put then in a liable situation and stink up their store to boot,maybe setting off alarms and having a visit from the fire department.
At the end of the presentation I was approached by a member wanting to buy the unit since I was not going to do anymore of this type of woodburning, and he had 2 small 8 & 10 yo. boys tagging along, I refused to do that , I could never sleep at night if I did. another member approached me and I refused him also ,until he told me he was a licensed electrician and worked Hi voltage quite often and was also an Electrical Engineer. After taking to him and confirming in my mind he is what he says , I sold the unit to him, with the feeling that he knew enough to check out the specs and wire insulation stamp along with the UL label and said it was a well built unit.
I also found out that the gloves I was using were not rated ClassII but only for 500v. Class II hi voltage gloves start about $180 and above. Mine only cost $30 and were rated class 00. (That made me wipe my brow).
Herb Stoops is online now
post #2 of 9 (permalink) Old 05-26-2017, 07:20 PM
Semipro's Avatar
First Name: John_*
Good for you not letting greed go to your head and making sure he was smart enough to use it, like you I would hate to know that hurt someone
billyjim and Herb Stoops like this.
Semipro is online now
post #3 of 9 (permalink) Old 05-26-2017, 07:45 PM
KUDOS to you Herb...
Herb Stoops likes this.
post #4 of 9 (permalink) Old 05-26-2017, 07:50 PM
vchiarelli's Avatar
First Name: Vince
Safety (of others as well) should be everyone's priority, far above profits. I like your integrity Herb.
billyjim, Nickp and Herb Stoops like this.
vchiarelli is offline
post #5 of 9 (permalink) Old 05-26-2017, 07:51 PM
RainMan 2.0's Avatar
+1
Scary hearing about the gloves though . I think I'll just pass on this technique
Ok ,I never insulate
RainMan 2.0 is offline
post #6 of 9 (permalink) Old 05-27-2017, 07:25 AM
First Name: Richard
Bravo, Herb.
Shop guy is offline
post #7 of 9 (permalink) Old 05-27-2017, 07:59 AM Thread Starter
Update: it was pointed out on another forum by someone who uses Class II andClass III gloves that they are required to be tested every 3 months and air tested daily. None of that information is ever disseminated on these videos of fractual burning.
https://www.grainger.com/content/qt-...inspection-262
post #8 of 9 (permalink) Old 05-27-2017, 08:13 AM
schnewj's Avatar
Thank you, Herb...I was just about to post that info.
HV is nothing to monkey with. Even the best HV electricians can make a mistake. One of the members of our HV crew flash burnt his arm on a 13,800 Volt line to the tune of $1/2 M in medical bills.
Although I was fascinated with the process, I'll definitely pass.
schnewj is offline
post #9 of 9 (permalink) Old 05-28-2017, 01:28 AM
jj777746's Avatar
We are lucky to have you with us Herb & pleased you wont be continuing this dangerous hobby any more.By the same token,you were pretty good at it from what I've seen.
+1 as Stick 486 & others said "KUDOS to you"! Jamesjj
You can't drive a bridge spike with a tack hammer(so I'm told)
jj777746 is offline
Presentation diazenr New Member Introductions 3 11-11-2013 02:11 AM
presentation wood44 New Member Introductions 3 04-12-2010 01:41 AM
Presentation Arrakis23 New Member Introductions 2 03-20-2010 03:16 AM
presentation lolo90 New Member Introductions 6 02-08-2010 02:15 AM
NE Bowl Presentation Mitch12 Woodturning and Lathes 16 06-13-2008 12:27 AM
