Graphite paper for tracing ? - Router Forums
post #1 of 9 (permalink) Old 11-30-2009, 09:20 PM Thread Starter
First Name: Bill or William
Default Graphite paper for tracing ?
I have read that graphite paper should be used for tracing patterns for pyrography rather than ordinary carbon paper.
Called my small town stationery store because there are no hobby stores here and they want almost a dollar a sheet for 12 x 16 size.
Seems rather expensive.
williamyoung is offline
post #2 of 9 (permalink) Old 11-30-2009, 10:20 PM
pyrography paper you can pick it up at your front door
Amazon.com: pyrography paper
post #3 of 9 (permalink) Old 11-30-2009, 10:25 PM
I just use carbon paper on pine. I also use carbon paper to trace letters on wood some times.
vikingcraftsman is offline
post #4 of 9 (permalink) Old 11-30-2009, 11:32 PM Thread Starter
I wonder if we are thinking of the same thing. ?
I thought the graphite paper was something similar to carbon paper where you put it under a pattern or picture to trace an outline right onto the wood and then remove the pattern and the paper out of the way . ..
How does this work ? . A quote from Amazon on their pyrography paper .
Technical Details
Pyrography paper used to burn patterns onto wood.
Can burn right through the paper
Product Description
Product Description
You trace, draw, or print (on an inkjet printer, laser printer, or copier) a design on PyroPaperTM, cut around the tracing, tape it to your wood or gourd, and woodburn right though it! 50 Sheets (not pictured)
What happens to this paper if you burn right through it? Does it wrinkle and smoke or does it hold the pattern to it . Never heard of anything like that? Goes to show that I am not even a rookie burner yet
post #5 of 9 (permalink) Old 12-01-2009, 12:46 AM
Ok I have used grafite paper it came with some stencils.But because I am cheep I just trace things on to what I intend to burn. The grafite paper just held up to the heat leaving the pattern on the wood. No fire like you would get with cheap carbon paper.
post #6 of 9 (permalink) Old 12-01-2009, 01:14 AM Thread Starter
That's interesting .
I have a lot to learn while waiting for my burning equipment to arrive.
BTW
I tried to edit my profile a few times to put in a signature . It previews fine but does not take when I hit submit signature.
I will see if I can post it here as a non signature.
This is my PictureTrail albums showing some of the stuff that keeps me out of mischeif (sometimes)
PictureTrail - Gallery
Now on a preview it shows both the link I provided as well as the signature link which are both the same.
Perhaps it just took a while for the signature link to take effect.
post #7 of 9 (permalink) Old 12-01-2009, 04:44 AM
Bob N's Avatar
First Name: Bob
Hi Bill,
I visited your web site and see that you are a very accomplished turner and scroller.
Nice work and we are glad to have you join with us. Perhaps we can learn from you as well
Bob N is offline
post #8 of 9 (permalink) Old 12-01-2009, 07:43 AM
First Name: Greg
Bill,
I use Saral graphite transfer paper. It comes in a 12' x 12-1/2" wide roll and it was like $7 at the local fabric store.
It seems to work well and is easy to erase.
Saral Paper Corporation: Products and Uses
Very nice work on the clocks!
Greg
gregW is offline
post #9 of 9 (permalink) Old 12-01-2009, 01:00 PM
BigJimAK's Avatar
Wow, Bill.. Nice gallery! ..and yes, your signature is now working.
BigJimAK is offline
Micro fiber or micro-mesh paper...? anotherBob The Finishing Touch 0 11-05-2009 10:23 PM
Dovetailed waste paper bin. derek willis Table-mounted Routing 14 02-08-2009 03:21 AM
Look for a product with graphite reible Tools and Woodworking 9 02-21-2008 12:20 PM
Sanding paper everywhere... simplenik Tools and Woodworking 7 06-02-2007 12:57 AM
