Today's Practice Burn - Router Forums
post #1 of 7 (permalink) Old 12-28-2009, 09:17 PM Thread Starter
First Name: Bill or William
Default Today's Practice Burn
Tried this one today. It's not a keeper. I just stuck it in a frame temporarily for the picture. .
Apart from the two large dark areas the pattern was just black lines on a white background.
I tried my shading tip on this one for my first practice with a shading tip. I have a lot to learn about shading but it was a start and I didn't want to overdo it.
I messed up the girls hand but I think I will be able to scrape or sand that off and re-do that part . It happened because although I thought I had the the Baltic birch plywood sanded enough to 400 grit there were still some little "pockets" in the grain where the burning tip paused for a split second too long.
I have been told that once I start on softer wood like basswood , I won't have that problem as much. Don't want to try one of my basswood rounds or ovals until I have had more experience . I will continue on BB until I get a little more confident .
williamyoung is offline
post #2 of 7 (permalink) Old 12-29-2009, 04:21 AM
Bob N's Avatar
First Name: Bob
Bill,
That is some excellent burning! You are certainly a perfectionist in your work.
Bob N is offline
post #3 of 7 (permalink) Old 12-29-2009, 10:39 AM
CanuckGal's Avatar
First Name: Deb
Bill you are certainly making leaps and bounds in your "practice" work. That is very nice!
I measured, I marked, I cut.
CanuckGal is offline
post #4 of 7 (permalink) Old 12-29-2009, 12:03 PM
Very nice indeed.
vikingcraftsman is offline
post #5 of 7 (permalink) Old 12-29-2009, 12:22 PM Thread Starter
Thanks for the nice comments from all.
I find this art form so much more relaxing than all the scroll sawing I used to do so much of and most any pattern can be adapted to use for burning whether it is a scroll saw pattern or just a picture from a coloring book or otherwise. I have a whole different outlook on coloring books now. I always considered them kids stuff until I found the more advanced ones that Dover books have to offer on line for free . That one I just finished is a Dover pattern. With burning there is not the problem of having "floaters" in the patterns like in fretwork because nothing is cut out .
Once I get the outlining and shading to the point I am happy with it I will probably get into coloring as well .
With scroll sawed portraits it in customary to put either black or a color material on the back to show through the openings but I have not seen any with shading and actual colors on the top side .
I think coloring is going to add a whole new dimension to the burnings once I get to that point.
post #6 of 7 (permalink) Old 12-29-2009, 02:08 PM
Thank you for sharing you work and thoughts. I use reeves oil pastel set. Mostly because that is what was at the carft store. I am happy with them though. Enjoy your burning.
post #7 of 7 (permalink) Old 12-29-2009, 03:16 PM
Gene Howe's Avatar
First Name: Gene
That's really nice. And, it's a keeper, in my book!
Gene Howe is offline
Specialty Burn Through Paper ? williamyoung Pyrography and Carving 9 12-21-2009 03:51 PM
My First Burn williamyoung Pyrography and Carving 5 12-08-2009 05:33 PM
Pyrography practice vikingcraftsman Pyrography and Carving 2 12-02-2009 09:12 PM
Practice projects that didn't go ka-flooie! rwyoung Woodturning and Lathes 11 04-06-2009 10:17 PM
Burn marks rosq General Routing 5 10-31-2007 07:03 PM
