Mallet Removing Paraffin Wax From It - Router Forums
post #1 of 4 (permalink) Old 12-03-2010, 02:06 PM Thread Starter
Gaia's Avatar
First Name: Peter
Default Mallet Removing Paraffin Wax From It
Hi,
I received my 3 1-2 inch 20 oz Lignum Vitae Carvers Mallet a few days ago.
In how to carve wood by Richard Butz, ( I wasn't able to locate to locate a mallet turned from a single solid piece of lignum vitae like his.) Mine has a 3 1/2 inch lignum vitae head and ash handle.
In Mr Butzes book he talks about a new mallet being covered in thick paraffin wax, to protect it during shipping.Mine does not seem to have any wax covering. He goes on to say, scrape it off and rub it down with fine 000 steel wool. He says the wood still has to be sealed to keep its moisture in, if lignum vitae dries out to quickly, it may crack and check He suggests applying a liberal amount of boiled linseed oil letting it soak in overnight, then wipe it dry with a clean rag.
I'm wondering, should I get some boiled linseed oil and apply it to the mallet???
Mr Butze says The mallet will then be ready to use, although it is a good idea to oil it once a week for the first month or so..He says if notice any cracks appearing in the end grain , try storing the mallet in a plastic bag with a few drops of water when not in use. It may take several months for the lignum vitae to stabilize to ones particular climate.
I was wondering what other peoples views were?
Cheers.
Gaia is offline
post #2 of 4 (permalink) Old 12-03-2010, 02:48 PM
Gene Howe's Avatar
First Name: Gene
I would suggest that you do the soaking. It can't hurt. In fact, I'd soak the handle as well.
What is the average humidity in your shop or where the mallet will be stored?
You might consider the water in the bag, also.
Gene Howe
Snowflake, AZ
Gene Howe is online now
post #3 of 4 (permalink) Old 01-14-2011, 11:23 AM
Capecarver's Avatar
First Name: Steve
I have several lignum vitae mallets, and truthfully, I've never done anything to them.
One of the older ones has a crack, and a couple are pretty worn from using with steel ferrule handles, but the others are just fine.
I don't see anything wrong with the advice you've seen in the book, though. Certainly can't hurt.
Capecarver is offline
post #4 of 4 (permalink) Old 01-14-2011, 04:39 PM Thread Starter
Gaia's Avatar
First Name: Peter
Cheers.
Gaia is offline
Is Goo Gone safe for removing adhesive? timbertailor The Finishing Touch 6 10-08-2009 10:00 AM
Lets go for a spin - Wood Mallet RMilgie Woodturning and Lathes 5 08-14-2009 08:55 PM
What Kind Of Wax Do You Use dgleason Tools and Woodworking 20 02-20-2009 10:53 AM
Paste Wax for MDF Jig? RoyBullets Jigs and Fixtures 16 08-19-2008 09:22 PM
Wax... for tools reible General Routing 0 01-13-2005 12:08 AM
