when to add color when staining artwork - Router Forums
post #1 of 4 (permalink) Old 12-21-2010, 02:27 PM Thread Starter
First Name: Tawni
Default when to add color when staining artwork
I was wondering when to add color to a pyrography project when I am planning on also staining it. It is a large toybox that will have characters on it that will be shaded and colored but also with a hint of stain to darken the entire piece. Obviously I will be adding an enamel to it in the end. Anyone know what comes first, the stain or the color?
tfiddle is offline
post #2 of 4 (permalink) Old 12-21-2010, 06:09 PM
dutchman 46's Avatar
First Name: Howard
I have never tried to do both. It is probably a chicken and an egg question, Which came first? I would think that if I were trying to make that decision, I would stain first, let that dry, and then paint, let it dry, and then add Your clear finish to add the sheen.
John 3:16
dutchman 46 is offline
post #3 of 4 (permalink) Old 12-22-2010, 09:02 PM
lathman's Avatar
First Name: rod
i'm with dutchman on this one.......
lathman is offline
post #4 of 4 (permalink) Old 01-14-2011, 11:10 AM
Capecarver's Avatar
First Name: Steve
It depends on the look you're going for.
If you want the colors to be bright or new looking, go with the stain first.
If you want a more antiqued look, stain after.
One thing to consider if you stain after painting is that the staining can break up and erode the paint if they are the same base. So either use different bases (ie: acrylic paint, oil stain), or at least let the paint cure very well before wetting with stain.
Hope this helps.
Capecarver is offline
The Secret To Staining Wood? StormStrikes The Finishing Touch 10 03-06-2011 01:23 PM
