How Do I Reshape This V Gouge? - Router Forums
post #1 of 3 (permalink) Old 09-14-2012, 03:29 PM Thread Starter
Gaia's Avatar
First Name: Peter
Default How Do I Reshape This V Gouge?
I bought this V gouge from Ebay. It has been ground unevenly on both sides. Looks like quite an aggressive removal of metal, I assume done on a high speed grinder. If it had been over heated, are bluing marks always visible as a tell tell sign?
I have a Tormek BGM 100 bench grinder jig that was thrown in free when I bought some Tormek jigs. Tormek says, " These instructions are exclusively for HSS turning tools, since dry grinding at high speed is not suitable for ordinary carbon steel tools
due to the risk of overheating and its aggressive steel removal. "
That said, is it possible to reshape this V gouge back to working condition? It would take forever on my wet stone grinder.
Thanks.
Gaia is offline
post #2 of 3 (permalink) Old 09-14-2012, 04:19 PM
I bought a Sorby corner chisel (similar to a V gouge) off ebay and it wasn't perfectly square either. I managed to get it very close using diamond hones. They are a bit tricky to sharpen even by hand. I found that I had to go across the cutting edge at an angle to get the point sharp. I should mention that I am talking about an in cannel grind as opposed to an out cannel. An out cannel should be quite easy.
post #3 of 3 (permalink) Old 09-15-2012, 01:37 AM Thread Starter
Gaia's Avatar
First Name: Peter
OK thanks.
Gaia is offline
bowl gouge Ron C Woodturning and Lathes 4 01-19-2010 10:02 AM
bowl gouge Ron C New Member Introductions 2 01-18-2010 09:26 PM
Gouge sharpening system Glenmore Woodturning and Lathes 2 08-15-2009 10:27 AM
Bowl Turning and Re-Turning BernieW Woodturning and Lathes 16 04-17-2009 08:03 PM
