Carved and burned - Router Forums
post #1 of 20 (permalink) Old 09-14-2012, 07:03 PM Thread Starter
Iceman567's Avatar
First Name: Ted
Default Carved and burned
Finally got around to posting some pics of my carvings. I finished these up this past spring. I took a class from Fred & Elaine Stenman Stenman Studios - Home - unique blend of refief woodcarving and wood burning. They teach shallow relief carving, HEAVY burning and then painted with thinned acrylic paints. The heavy burning keeps the paints from bleeding into adjacent areas. The barn and tree is the first project. Then you can choose one of their patterns or have one modified to your liking. They are excellent teachers and are always giving you tips and hints. The second one was completed in class and the others I completed on my own at home.
Iceman567 is offline
post #2 of 20 (permalink) Old 09-15-2012, 07:34 AM
First Name: Bob
Ted ~ Absolutely beautiful. Thanks for sharing and also providing some information about your technique.
Web Shepherd is offline
post #3 of 20 (permalink) Old 09-15-2012, 07:50 PM
First Name: Frank
To you, I say Congrats. If I had this much talent, I'd leave town and make a brand new living. This is beautiful, you have done some great work.
Tagwatts1 from Utah
Tagwatts1 is offline
post #4 of 20 (permalink) Old 09-15-2012, 08:43 PM Thread Starter
Iceman567's Avatar
First Name: Ted
Thanks to you both. Don't know about making a living though. As long as it took to carve those I'd starve!
As much woodworking I've done over the years, I'd never picked up a carving knife. Last winter we were in Texas and I decided to give carving a try. I had some excellent carvers for teachers. The wood burning was mostly self-taught from some good books from Fox Chapel Publishing. The nice thing about carving, it's quiet, not a need for many tools and you can bring it just about anywhere.
The trouble with quotes on the internet is that you never know if they are genuine. - Abraham Lincoln
post #5 of 20 (permalink) Old 09-16-2012, 06:21 AM Thread Starter
Iceman567's Avatar
First Name: Ted
Here are a few more that are just woodburned. These are burned onto 3/8" thick basswood. I use several different methods for transferring a pattern. Graphite paper , the non-wax type and can be erased. Most craft stores carry this or can be found on-line.
The OH transparency method. Using an ink jet printer, print your pattern out onto an overhead projector transparency (remember those from days by gone). You might have to flip your pattern before you print it so it is oriented the right direction. Lay the transparency onto your piece of wood, ink side down, secure with blue masking tape. Rub the face of the transparency with the edge of a credit card, small scraper,etc. The ink pattern will transfer onto your wood. One suggestion is to change the color of the pattern before you print, usually a medium brown will work. If you get off a line when burning you won't have an ugly black line showing.
The last method is pyrography paper (Pyrography Paper* from Smoky Mountain Woodcarvers Supply). Similar to an OH transparency but you can burn right through it when transferring a pattern, and you won't set your house on fire!
With most patterns I only transfer the main parts to the wood. Intricate details usually won't show up and need to be added without the use of a pattern.
Go burn something
post #6 of 20 (permalink) Old 09-18-2012, 04:45 PM
Humbled by your pieces. They are absolutely spectacular !!!
Fishinbo is offline
post #7 of 20 (permalink) Old 09-20-2012, 03:30 PM
Taking a different approach from the conventional ones. Always inspiring.
steamfab is offline
post #8 of 20 (permalink) Old 09-20-2012, 06:54 PM
First Name: Bob
Ted, I recently started wood carving, mainly caricatures, and my work doesn't come close to the quality of yours. Your work is really impressive and demonstrates your considerable talent. Bob.
Singinsam is offline
post #9 of 20 (permalink) Old 09-20-2012, 08:22 PM Thread Starter
Iceman567's Avatar
First Name: Ted
Fishinbo and steamfab thanks. The comments are appreciated. I sometimes think my work isn't good enough and the favorable comments shores up my confidence.
Bob, I started out doing some simple eye, nose ear and mouth carvings on a 2" square piece of basswood. Fox Chapel Publishing has a series of books Woodcarving that I was able to borrow that helped a lot. I usually spend at least an hour a day carving. It DOES take lots of practicing. Make sure you count fingers and thumbs when you are done.
Good luck and have FUN.
post #10 of 20 (permalink) Old 09-20-2012, 10:01 PM
TRBaker's Avatar
First Name: Troy
Nice work, Ted. Make sure you keep it up and post your work for our pleasure. Thanks
Troy
TRBaker is offline
