Woodburning straight lines - Router Forums
post #1 of 3 (permalink) Old 10-23-2012, 05:41 PM Thread Starter
EnRouteWoodcrafts's Avatar
First Name: Charlie
Default Woodburning straight lines
I have been woodburning for a while now and feel like im pretty good at it but the problem im having most is trying to get a thin straight line with one of the thin pointed tips. Any advice on how to make my thin lines look straight and not wobbly?
EnRouteWoodcrafts is offline
post #2 of 3 (permalink) Old 10-24-2012, 07:10 AM
Iceman567's Avatar
First Name: Ted
A few possibilities. Not sure what you are burning the lines into. A small V-gouge and using a straight edge, carve a very shallow v-groove and burn that. Or use a wooden ruler with the thin metal strip on the edge. Too much metal will draw the heat out of your tip.
Good luck.
The trouble with quotes on the internet is that you never know if they are genuine. - Abraham Lincoln
Iceman567 is offline
post #3 of 3 (permalink) Old 01-17-2013, 08:02 PM
First Name: Thomas
Hello Enroute,
A couple of things that I have used. A pre-drawn line drawn with a graphite pencil, or patterned onto your design using a laser printed line and a patterning bit/heat bit, or a household iron gives you a line to follow and goes will with tracing skill.
As iceman said metal will draw heat from the tip and wood will burn, but if you raise a small metal bar up so it is touching the pyro-pen shaft above the tip it doesn't cool the tip and can act as a guide, raised up and clamped on two short wooden blocks, can give a good mount.
And of course remember it's easier to draw a straight line if you're drawing it diagonally towards your dominant hands side (motor neuron theory) rather than drawing one across or straight down from your bodies perspective. So rotating the piece to the right angle can help.
Galaktia is offline
Plunging straight bits crquack Router Bits - Types and Usage 17 04-16-2010 12:25 AM
straight bit / spiral bit (solid carbide bit?) hyiu Router Bits - Types and Usage 3 04-13-2010 09:09 PM
Straight vs Plunge Bits kolias Router Bits - Types and Usage 16 09-13-2009 01:17 PM
Makita RF1100, 1101, RD1100, 1101 Straight Guide markus General Routing 4 01-20-2009 11:46 AM
straight bits TWheels Router Bits - Types and Usage 3 09-16-2006 04:32 AM
