Lobster - Router Forums
post #1 of 10 (permalink) Old 12-27-2012, 04:55 PM Thread Starter
Iceman567's Avatar
First Name: Ted
Default Lobster
This was carved into 1" thick basswood, about 1/4" of the background taken out with a #3 X 3/4" chisel. The entire lobster was wood burned around the edges to keep the red paint from bleeding into the background.
Painted with thinned acrylic paints. The background was painted with a thinned antique medium. Then the whole board was given a 'wash' with a mixture of mineral spirits and burnt umber oil paint.
A blue crab carving in the works now.
The trouble with quotes on the internet is that you never know if they are genuine. - Abraham Lincoln
Iceman567 is offline
post #2 of 10 (permalink) Old 12-27-2012, 05:43 PM
Gaffboat's Avatar
First Name: Oliver
Very cool! How will it be used? It looks like decor for a restaurant.
Gaffboat is offline
post #3 of 10 (permalink) Old 12-27-2012, 08:00 PM
great result, Ted.
Sydney, Australia
jw2170 is offline
post #4 of 10 (permalink) Old 12-28-2012, 01:35 PM
Great carving! Like the color, looks really realistic.
BandSaw Blades Online - Custom Welded Band Saw Blades
steamfab is offline
post #5 of 10 (permalink) Old 12-29-2012, 07:39 AM Thread Starter
Iceman567's Avatar
First Name: Ted
Thanks. If I don't sell it, I'll add it to my inventory for a few craft fairs in 2013.
post #6 of 10 (permalink) Old 12-29-2012, 07:46 AM
knuttypine's Avatar
First Name: Lawai'a
wow, nice work. Looking forward to your next project. And maybe a little more detail about the finishing and the burnt edging to prevent the paint movement. Thank you
knuttypine is offline
post #7 of 10 (permalink) Old 12-29-2012, 08:26 AM Thread Starter
Iceman567's Avatar
First Name: Ted
I took a three day carving class in Texas last winter. It was given by Fred & Elaine Stenman Stenman Studios - Home - unique blend of refief woodcarving and wood burning. They teach shallow relief carving (1/4" or less). wood burning and painting.
1. With the carving completed and sanded, I generally use a skew tip or a flat shader. I have a Colwood Wood Burner that I set the temp fairly high. Follow the edge of the carving making a 'seal' between the carving and background. Leave no unconnected burned line, paint will flow through.
2. I use Ceramcoat Acrylic paints, one the Stenmans use also. I thin the paint with water to the desired opacity, that's your call. With the lobster I brushed the carving with clear water first so when you paint it, there's more consistency-paint doesn't blotch. The one draw back with using this much water, it has a tendency to raise the grain of the wood.
3. Final finish - everybody has their favorite. This one I used MinWax satin lacquer spray, about four or five coats. Sanding with 400 grit sandpaper between coats.
Hope this helps.
post #8 of 10 (permalink) Old 12-31-2012, 05:52 AM
knuttypine's Avatar
First Name: Lawai'a
Thank you 4 sharing, I appreciate the insight/tips
post #9 of 10 (permalink) Old 04-18-2013, 02:24 PM
oercili's Avatar
Country: Turkey
First Name: Orhan
wow hard to believe that wood carving, has been wonderful.
Wood carving is a state of the tree after my death.
www.intarsia.tr.gg
oercili is offline
post #10 of 10 (permalink) Old 04-19-2013, 01:59 PM
Like it. Great carving on the lobster, great attention to details and the mix of paints/colors.
Camero68 is offline
Larry the Lobster (Pics and Vid)… Nickbee Show N' Tell 19 08-08-2011 12:19 PM
Christmas Toys....lobster Lee Brubaker Show N' Tell 4 07-18-2008 09:53 AM
