Duplicating - Router Forums
post #1 of 5 (permalink) Old 02-28-2013, 02:38 PM Thread Starter
First Name: Henry
Default Duplicating
Duplicating a comfortable walking cane head and designs is a goal of mine. I have a stock of various hard wood sticks dried that have tops or former branches attached, but no such equipment. I imagine clamping the stick vertical and a router mounted that moves up and down and sideways as a offset lever is guided over a pattern of already good shaped head, pattern or form. What is available? Are there plans of building one?
OIB-HENRY is offline
post #2 of 5 (permalink) Old 03-01-2013, 06:28 AM
I built the unit from copycarver.com and like how it works. There is a learning curve, but it is very good for 'roughing out' your carvings. I see videos of machines doing finished work, but I have my doubts about it being practicle.
flockshot is offline
post #3 of 5 (permalink) Old 03-01-2013, 03:26 PM
JOAT's Avatar
First Name: Theo
Right now I have about 40 different designs for cane handles sketched out. At this time I only have about 3-4 cut out. I use 1/2" plywood, make a master, then use them for routing out my canes and handles. Right now I have two test canes I use, one pretty rough, and the other fair. As soon as I get another handle cut out and a new cane made, I'll be destroying these two - breaking them to see how much weight it will take to do it. Now just need a way of figuring out how to measure the weight. Here is a picture of my 'good' test cane. The picture is not great, because I had to enlarge it. The 'lozenge' below the handle is so people can have space to put info, or personalize, their cane.
JOAT is offline
post #4 of 5 (permalink) Old 03-01-2013, 09:12 PM Thread Starter
First Name: Henry
JOAT Thanks! The natural wood sticks I have gathered and dried are mostly from NC and Eastern US to Michigan and Canada. Henry
post #5 of 5 (permalink) Old 03-02-2013, 01:22 AM
First Name: DAVID
Welcome Henry
IRONMULE31014 is offline
duplicating carving machine beatty312 General Routing 1 06-16-2011 10:02 PM
Which bit? Duplicating lathe with mounted router msn56 General Routing 5 03-04-2011 02:26 AM
wood carving duplicating arnblack New Member Introductions 2 10-20-2010 01:12 AM
Duplicating Router set up Dave_Burley General Routing 0 09-07-2008 01:34 PM
