Mother of Pearl Inlay in Wood Help is Needed - Router Forums
 1Likes
  • 1 Post By alohaberkeley
post #1 of 5 (permalink) Old 07-06-2014, 03:23 PM Thread Starter
First Name: Alev
Default Mother of Pearl Inlay in Wood Help is Needed
Hello everyone,
I am in the process of building couple of bench style seats and want to do inlay of flat mother of pearl in the wood. I am experienced woodworker but never installed mother of pearls before. I would appreciate your help on:
- Best tools to use
- Instructions
- Videos you may want share
Attached is the design I want to do and any help you may provide
Name:	MOP Design.jpg
Alev is offline
post #2 of 5 (permalink) Old 07-07-2014, 03:32 PM
First Name: Wes
Alev, Here are some sites that are filled with info: 1)Luthiers Mercantile International aka LMI (lots of info, tools and tips) 2) Stewart MacDonald aka Stewmac (another luthier site with vids, how-tos & tools. 3) DePaule Supply amazing amount of materials and info. 4)Grizzly Industrial.com (inlay material and tools- owner makes guitars so there is a fair sized luthier section. 5) Lumberjocks (you may have to sign up to access search functions) search for "Mother of Pearl inlay" in Forums, projects or classes. 6) YouTube has a ton of inlay vids- I don't have links, but a search will get you more how to's than you'll need. 7) I'd be remiss if I don't toss in Larry Robinson- the most incredible, beautiful inlay work I have ever seen.
I know these are sites mainly for luthier's but the materials, tools and techniques apply to what you want to do. My basic tool kit contains a jewelers fret saw, a deep reach fret saw, a bird's mouth (for cutting materials on), a good light source, a Dremel (or a small router like the Colt). I use a Dremel with a Stewmac Dremel base -expensive but accurate as all get out. The 2 most important items are items we should all have in arm's reach- a good dust mask and eye protection. The pearl dust is toxic and it chips easily so it's wise to be protected.
Hope this helps in some small way....................Wes
Gaffboat likes this.
alohaberkeley is offline
post #3 of 5 (permalink) Old 07-14-2014, 11:42 AM Thread Starter
First Name: Alev
Thank you for the information Wes, I will define tally check these sites. I agree with the safety tips for sure. Appreciate your recommendations.
Alev
Alev is offline
post #4 of 5 (permalink) Old 07-14-2014, 03:10 PM
Semipro's Avatar
First Name: John_*
Alev
If you get this worked out would like to hear and see how it comes out.
Semipro is online now
post #5 of 5 (permalink) Old 11-19-2016, 06:04 PM
First Name: Scott
You might check out using crushed mother of pearl with CA glue or epoxy.
It is VERY easy to use.
For small inlay patterns like yours this would be much easier.
good luck
https://www.amazon.com/Mother-Materi...ords=imaginlay
scottgrove is offline
Introduction to Wood Species... BobandRick Wood Species 40 03-19-2015 12:03 PM
Framing a small piece of wood lea6141 Table-mounted Routing 10 08-19-2010 04:01 PM
Inlay and wood movement verteramofurniture Guide Bushings and Templates 3 02-16-2009 02:45 PM
Router template inlay V Garry General Routing 7 12-27-2008 06:49 PM
How to identify wood species: allthunbs Tools and Woodworking 11 12-04-2008 12:28 PM
