Branding Iron - Router Forums
 1Likes
post #1 of 11 (permalink) Old 11-11-2014, 10:07 AM Thread Starter
Badger2's Avatar
First Name: Malcolm
Default Branding Iron
Does anyone use a 'branding iron' for their work. I mean a small symbol - a makers name or the like to burn onto their work? Nothing too fancy and possibly heated on a flame rather than electric/battery? Imges would be good?
Malcolm
Badger2 is offline
post #2 of 11 (permalink) Old 11-11-2014, 11:10 AM
Lee Valley has featured both types of irons in their catalog, i.e. electric and heat with a torch. They also offered custom irons rather than a few initials and a last name.
post #3 of 11 (permalink) Old 11-12-2014, 10:50 AM
rrrun's Avatar
First Name: Henry
I brand all of my work with an electric iron.
It is difficult to get a "perfect" image ... I often have one end lighter than the other. That's because it's difficult to keep the branding iron perfectly vertical for the 20 seconds or more required to burn the perfect image. Also, I've found that heating an end grain cutting board results in the pieces de-laminating a bit on the heated joint.
Your mileage may vary ... and if anyone else has a better solution, please share!
Henry
Santa Clarita, CA
www.MowryJournal.com
rrrun is offline
post #4 of 11 (permalink) Old 11-12-2014, 01:46 PM
neville9999's Avatar
First Name: Neville
Send a message via Yahoo to neville9999
Malcolm
Malcolm getting a branding Iron with a personal logo on it is a great idea and it will let you personalize your work in some distinctive way, I have seen some very nice ones, I have not had one made yet but I will, Just Google 'Electric Branding Irons' and talk to them, do say how you go. N
neville9999 is offline
post #5 of 11 (permalink) Old 11-12-2014, 04:36 PM
First Name: Ron
I got an electric one from Rockler for Christmas last year from my daughter. It is nice to personalize my projects and I know the kids will remember grandpa for some time. I do find it difficult to get an even burn however I have found if I rock the iron a bit vertically then follow with a slow rock horizontally, i get acceptable results.
Practice on scrap will perfect the process for you and your "giftees" will be impressed.
rweerstra is offline
post #6 of 11 (permalink) Old 11-13-2014, 12:38 AM
JOAT's Avatar
First Name: Theo
If you want to go really custom, rather than what you buy, you can chemically 'burn' the wood. Plenty easy to make a stamp of your own design, and plenty less expensive. I was going to do it to 'burn' some of my designs, but haven't gotten around to make the stamps yet. I plan on making a 'holder' for a Dremel clone, then routing a small grove, following the tracing of that particular design, in a piece of floor tile, then use clear silicone to make the stamp.
Chemical Woodburning | MAKE
And then it will 'really' be your design.
I'm not cheap, just usually short on money, but even so, it's one Hell of a lot more fun and satisfying to make your own.
JOAT is offline
post #7 of 11 (permalink) Old 11-13-2014, 09:44 AM
Gaffboat's Avatar
First Name: Oliver
That's an interesting technique, Theo. Thanks for the idea and the link.
Gaffboat is offline
post #8 of 11 (permalink) Old 11-13-2014, 01:29 PM
JOAT's Avatar
First Name: Theo
No prob. If youse has gots info, pass it along, that's the way it's supposed to be.
That said, you could actually make a real branding iron without major hassle. Electro etching, you can etch using a D cell battery, it's that simple. However, in truth, you would want something that would etch a bit deeper than a D cell would allow. But, if you make a mistake, or want to change your branding iron, or whatever, I think the silicone stamp and chemical woodburning would be the way to go, besides no heating and all.
I should be able to dig up a photo or two of some of my early etching tries.
JOAT is offline
post #9 of 11 (permalink) Old 11-14-2014, 06:04 AM
JOAT's Avatar
First Name: Theo
OK, found some pictures. I used Altoid tins, cleaned off all the lettering and such on the bottom, sprayed with a coat of primer, inked designs on them, followed the lines with a sharp pointed tool, etched, cleaned the primer off, and viola. Etched designs. You can get some fantastic detail this way. If I were making a branding iron I would leave the lines covered, clear the primer off between the lines, so when it was etched the lines would stand out and burn the wood, giving you your design.
JOAT is offline
post #10 of 11 (permalink) Old 11-14-2014, 06:21 AM
+1 on the LeeValley...
Machinist opinion re: General cast iron table not flat? corth Table-mounted Routing 43 12-11-2014 07:27 PM
Some More On Keeping Cast Iron Clean Jerry Bowen Tools and Woodworking 18 10-26-2012 09:42 PM
cast iron tops? springwoodindustries New Member Introductions 4 10-26-2009 01:34 AM
Branding irons. AxlMyk Tools and Woodworking 4 03-31-2008 04:47 PM
need advice for inserting rosseau router plate into bench dog promax cast iron table sf_basilix Table-mounted Routing 7 02-21-2008 07:00 PM
