Can i seal prior to routing a piece of wood - Router Forums
post #1 of 10 (permalink) Old 11-23-2014, 03:13 PM Thread Starter
First Name: Nathan
Default Can i seal prior to routing a piece of wood
I am making some decorative boards using a cnc router. I want to keep the natural look of the wood except for where I'm routing. I was thinking I could seal the side I'm going to route prior to doing so and then stain the newly routed areas and wipe off the excess. I was originally going to route, stain and then sand, but some of the more decorative areas are not very deep. All suggestions are helpful..also I'm routing Oak
nhargrove63 is offline
post #2 of 10 (permalink) Old 11-23-2014, 03:43 PM
Semipro's Avatar
First Name: John_*
Nathan ,welcome to Router Forums, glad to have you join us, I'm positive the members of the community would be more than willing to answer any questions you have.
I do not see any reason you can not do it, you may run a test piece first
Thank You John
Semipro is offline
post #3 of 10 (permalink) Old 11-23-2014, 04:08 PM
agreed...
yes you can...
go for it...
post #4 of 10 (permalink) Old 11-23-2014, 04:22 PM
Welcome to the forum Nathan.
post #5 of 10 (permalink) Old 11-23-2014, 09:52 PM Thread Starter
First Name: Nathan
Default go for it
Thanks guys for the words of encouragement
post #6 of 10 (permalink) Old 11-24-2014, 06:51 AM
First Name: Keith
Nathan, actually that is the preferred way for CNC carvings. It seals the edge where your carving to prevent stain, or paint from entering the veins of the wood, causing small streaks around the carved area.
Keith Hodges is offline
post #7 of 10 (permalink) Old 11-24-2014, 03:15 PM
Garyk's Avatar
First Name: Gary
Naathan, not trying to steer you away from this forum, IT'S THE BEST AROUND, but I am on 3 or 4 CNC forums and a one dedicated to sign making. I learn from all of them. Just thought I would throw that out there as info.
Garyk is offline
post #8 of 10 (permalink) Old 11-24-2014, 04:05 PM Thread Starter
First Name: Nathan
Hey Garyk..what forum would you be talking about?
post #9 of 10 (permalink) Old 11-24-2014, 11:38 PM
First Name: Jeff
Nathan I make a lot of boxes and now completely seal the wood before making any cuts. I normally use a wipe on coat of shellac 1lb cut. I then lightly sand the face where I glue. On mitre cuts you don't have to sand at all. Glue can be wiped off where you don't want it without having to use masking tape. You can put any type of finish over shellac.
Regards Jeff
c3jrf is offline
post #10 of 10 (permalink) Old 11-25-2014, 02:24 AM
old55's Avatar
First Name: Ross
Ross,
old55 is offline
wood residential and business sign routing with mark disaverio New Member Introductions 10 06-08-2013 12:55 AM
What kind of wood for routing signs BC Wood Worx Sign Making 22 10-06-2011 01:09 PM
Holding wood for plunge routing harrysin Portable Routing 16 09-06-2008 10:53 PM
cnc wood routing SW&MI CNC Routing 11 11-06-2007 09:19 PM
Routing Wood Clock Gears. Wes Anderson General Routing 5 10-27-2007 12:22 AM
