Slotting bit - Router Forums
 3Likes
  • 2 Post By Cherryville Chuck
  • 1 Post By Nickdeck
post #1 of 7 (permalink) Old 08-29-2016, 01:24 PM Thread Starter
First Name: Nick
Default Slotting bit
Hello all. I've been lurking for a while and have a question. I have some experience with routers, but have never used a slotting bit. I just got a Whiteside, consisting of the arbor, a bearing, two washers, a nut and the cutting disc (3 cutters).
To attach the cutting disc, should I tighten the arbor into the collet, then tighten the nut (washer each side)? Can't see another way of tightening, short of grabbing the shank with some pliers, which sounds horrible.
Also, is it necessary to use the bearing? I'll be using the bit in a table router.
Thanks!
Nickdeck is offline
post #2 of 7 (permalink) Old 08-29-2016, 04:39 PM
Hi Nick and welcome. It is much easier to chuck the arbor and use your spindle lock or wrench to hold. I wouldn't use pliers on the bit shank as you can make burrs which could damage your collet. There may be some small washers with the set and they go against the inner race of the bearing so that the bearing will turn freely. If the outer race of the bearing sits against the slotter the bearing may not turn. If you don't use the bearing then you must use an edge guide or the fence on a router to control depth of cut. It wouldn't be that safe to use without the bearing otherwise.
The slot cutter is a very handy bit as you can make tongue and groove (with 2 cutters and a spacer), make a groove for splines with one, and biscuit slots with the right size cutter..
TWheels and Semipro like this.
post #3 of 7 (permalink) Old 08-29-2016, 04:53 PM Thread Starter
First Name: Nick
Thanks, Chuck. Tongue and Groove joints are exactly why I got the bit. Just learning, working my way through Pat Warner's joinery book.
Cherryville Chuck likes this.
Nickdeck is offline
post #4 of 7 (permalink) Old 08-30-2016, 01:02 AM
Forum Moderator
Semipro's Avatar
First Name: John_*
Hello and welcome to the forum. Nick
Thank You John
Semipro is online now
post #5 of 7 (permalink) Old 08-30-2016, 06:45 AM
Bushwhacker's Avatar
First Name: David
Hello and welcome Nick. We would all be happy to see what you are working on as you go.
When the enemy is in range, so are you.
Bushwhacker is offline
post #6 of 7 (permalink) Old 08-30-2016, 06:56 AM
Pat is a member of this forum and uses the user name Quillman.
post #7 of 7 (permalink) Old 08-30-2016, 09:27 AM Thread Starter
First Name: Nick
Yes, I knew that and have seen some of his posts. I have several of his products, as well as some of his books and .pdfs. Aside from the information I've absorbed, he's a hell of a craftsman.
Nickdeck is offline
Craftsman 1-1/2HP 315.17491 router severe vibration with t&g bit danmancalif New Member Introductions 4 02-19-2014 11:41 PM
Router Bit Woes - HELP! MT Stringer Router Bits - Types and Usage 14 10-24-2013 09:00 AM
straight vs. mortise?, and what bit for cleaning non-flat surface? achoox4 Router Bits - Types and Usage 9 12-17-2012 06:53 AM
Router Bit Set for Raised Panel Doors Hoss McGr Table-mounted Routing 8 10-17-2009 04:17 PM
Broken bit Mortice Router Bits - Types and Usage 3 02-20-2009 11:51 AM
