Router bit Maintence - Router Forums
 6Likes
post #1 of 20 (permalink) Old 09-01-2016, 02:14 PM Thread Starter
First Name: lee
Default Router bit Maintence
I just opened my cabinet to get something and noticed my router bits. They look like they need attention. I got my bits from a guy that pasted a while back and it looks like I need to clean them up. How do you guys maintain your bits? Do you soak them in some kind of cleaner? I guess you take the bearing off when cleaning the bit. Do you oil them every so often?
coxhaus is offline
post #2 of 20 (permalink) Old 09-01-2016, 02:39 PM
JOAT's Avatar
First Name: Theo
I do my routing with a 1/2" pattern bit, so they stay in the router, which is in the table, until the the bearing pops off. All I actually do is put 2-3 drops of light oil on the bearing before I start routing. The oil seems to make the bearings last a whole lot longer. Works for me.
jj777746 likes this.
JOAT is online now
post #3 of 20 (permalink) Old 09-01-2016, 03:01 PM
Nickp's Avatar
First Name: Nick
CMT or Trend bit cleaner...I use it on all cutting tools...saws, bits, blades, drill bits, and on and on...
Nick
Nickp is offline
post #4 of 20 (permalink) Old 09-01-2016, 04:24 PM Thread Starter
First Name: lee
I guess I could buy some bit cleaner. Is there any local products which I might already own like simple green or anything else which would work?
PS
What about chainsaw gas and an old toothbrush outside? Do you think it will remove the pitch and tar from the bit? It leaves an oily film from the 2 stroke oil.
coxhaus is offline
post #5 of 20 (permalink) Old 09-01-2016, 04:56 PM
Contributor of the Month
PS
Simple Green caught my attention. Soaking carbide bits in it supposedly leaches the carbide. There is another Simple Green product which I believe is advertised for cleaning aircraft aluminum....this is supposed to be ok for carbide soaking. I had soaked a carbide bit in regular Simple Green......didn't know it was a no-no. The bit took on a different finish after the soaking.....afraid to use it now.
JIMMIEM is offline
post #6 of 20 (permalink) Old 09-01-2016, 06:00 PM
same here...
post #7 of 20 (permalink) Old 09-01-2016, 07:28 PM
Nickp's Avatar
First Name: Nick
Lee...if you have a local hardware or tool store they are likely to sell the CMT bit cleaner...that's where I get mine...
Nick
Nickp is offline
post #8 of 20 (permalink) Old 09-01-2016, 07:57 PM
First Name: Clay
I have been cleaning bits with simple green for a long time with no problems. I do not soak them, just have a bowl of it and a brass brush. Clean them good, blow them out with air, oil the bearing.
I have at times used a diamond file on the flats, but usually just run them till they die and toss them.
fire65 is offline
post #9 of 20 (permalink) Old 09-01-2016, 08:03 PM Thread Starter
First Name: lee
I guess I will head over to Woodcraft and buy some CMT bit cleaner. I have some credit over there.
coxhaus is offline
post #10 of 20 (permalink) Old 09-02-2016, 12:11 AM
kp91's Avatar
First Name: Doug
Boeshield blade and bit works well
1 John 1:9
Fredericksburg, VA
kp91 is offline
Stuck Router Bit Noj Router Bits - Types and Usage 11 07-21-2014 04:18 AM
