Yonico Tongue & Groove Bits - Router Forums
 2Likes
post #1 of 15 (permalink) Old 09-05-2016, 02:49 PM Thread Starter
Default Yonico Tongue & Groove Bits
I am trying to set this up on my router table. my stock is 3/4" pine, I set the dept to 1/2", 1/4" is the tongue.. I set it up but when cutting the groove it leaves a feather edge, I try shimming, but that will change the tongue dimensions. First time using this setup. Thanks here is the photo of bits..
Sent from my SM-G900P using Tapatalk
bill.marshall.94 is offline
post #2 of 15 (permalink) Old 09-05-2016, 03:32 PM
I'm not sure I understand the problem Bill and it may be that we don't share the same terminology. I'm not sure what feather edge you are talking about.
post #3 of 15 (permalink) Old 09-05-2016, 03:35 PM Thread Starter
when creating the tongue it leaves a sliver on the edge, I have read others are see the same thing, they said to use utility knife to clean it up..
post #4 of 15 (permalink) Old 09-05-2016, 03:45 PM
First Name: Clay
OK, which edge, I still do not understand the question. Pictures?
fire65 is offline
post #5 of 15 (permalink) Old 09-05-2016, 04:10 PM
hawkeye10's Avatar
First Name: Don
Bill I can't be sure but it could be the bit. I have some of those bits and their quality isn't up to par with some others. Of coarse the price is good and we all like a good price. I now use my Yonico bits when it's not all that important I get the best cut. Just my opinion.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #6 of 15 (permalink) Old 09-05-2016, 04:33 PM
Honored Member
First Name: pat
Likely your stock varies in thickness just enough.
Have a caliper? Can you measure its thickness?
Maybe 25/32", std store S2S.
Quillman is offline
post #7 of 15 (permalink) Old 09-05-2016, 04:46 PM Thread Starter
yes I do will measure it, thanks..
post #8 of 15 (permalink) Old 09-05-2016, 08:00 PM
Are you jointing and planing your wood to a particular spec, or using big box wood? There is no such thing as straight, flat bigbox wood, so it could just be variations in the material's thickness and it not being straight. That bit brand is OK, not great. My default is Freud (available), but for anything exacting, like doors and T&G, my personal favorite is Sommerfeld Tools, which have matched sets and their wonderful EasySet setup jig, which accounts for exact stock thickness. Matched sets means you don't have to reset the second bit's height (you drop a half inch wide rubber grommet in the collet to form a reliable base). I LOVE the EasySet jig, and Sommerfeld has one for Freud bits as well.
DesertRatTom is online now
post #9 of 15 (permalink) Old 09-05-2016, 08:03 PM
Bill another thing to remember when making T & G is to always work from the same face. If it's flooring work from the backside. If it will be the back of a cupboard then work from the face. That takes care of one of the issues of uneven board thickness. I would also chamfer both the tongue and the groove.
post #10 of 15 (permalink) Old 09-05-2016, 08:34 PM Thread Starter
will do that, this set is a matched set, I will look for a rubber grommet. which should you cut first, I went with the tongue, then just used that to set the groove. Does that sound right?
3/8 tongue & groove assembly bit johannmendelsohn Router Bits - Types and Usage 10 09-08-2014 01:46 PM
Bolt removal on tongue & groove bit Router712 Router Bits - Types and Usage 10 12-18-2013 12:05 AM
Tongue and Groove Jig anyducks Jigs and Fixtures 0 04-05-2011 03:17 PM
Stopped Tongue and Groove mtnmaniac Router Bits - Types and Usage 3 08-29-2010 05:27 PM
Tounge & Groove with basic bits Soapdish Table-mounted Routing 4 08-04-2010 12:22 PM
