Slot cutter use on curves - Router Forums
post #1 of 5 (permalink) Old 09-09-2016, 11:02 AM Thread Starter
Default Slot cutter use on curves
I need to cut a 1-1/4" off the edge of a piece of laminated plywood/solid wood/plywood sandwich together and need to only remove 1/16" kerf. Could I do that with a slot cutter. The issue is that I will need to cut a radius. This is also done free hand. The piece cut off needs to be use in the build. Was thinking jigsaw but the problem is that the piece being cut is standing vertical
M
misterbig is offline
post #2 of 5 (permalink) Old 09-09-2016, 12:59 PM
Honored Member
First Name: pat
No.
1/6" , you mean 1/16"?
Quillman is offline
post #3 of 5 (permalink) Old 09-09-2016, 01:32 PM Thread Starter
Correct 1/16. I am trying to find a up cut spiral bit that is smaller than 1/4 inch that is longer than 3/8" long and not having luck. I have a slot cutter that would cut 7/8" in and thought that would work
Maybe dremal tool will work?
post #4 of 5 (permalink) Old 09-09-2016, 04:28 PM
hawkeye10's Avatar
First Name: Don
I don't think you will find a longer than that. It's because they will break very easy.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #5 of 5 (permalink) Old 09-10-2016, 01:07 AM
TWheels's Avatar
I am very unclear as to what you need to do. Can you draw a picture, post a photo, etc?
FYI Lee Valley is one place that sells Onsrud solid carbide upcut bits, for example 3/16 inch diameter, 3/4 inch cutting depth.
http://www.leevalley.com/US/wood/pag...435,46171&ap=1
I Hope to Be the Person My Poodles Believe I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is offline
newbie question freud 58-112 slot cutter lking Router Bits - Types and Usage 3 04-10-2014 08:13 PM
Biscuit cutter or slot cutter on router table Jerry Bowen Tools and Woodworking 7 09-14-2013 09:16 AM
Profile Cutting Cutters and their Bearings neville9999 Jigs and Fixtures 7 12-10-2012 01:11 PM
The use of a Router table as a Profile Copier neville9999 Jigs and Fixtures 4 12-06-2012 11:44 AM
Slot cutter question schmoo Router Bits - Types and Usage 5 04-09-2012 07:04 PM
