Is there a router bit to make this edge? - Router Forums
 1Likes
  • 1 Post By Stick486
post #1 of 8 (permalink) Old 10-04-2016, 01:28 PM Thread Starter
Default Is there a router bit to make this edge?
Is there a router bit that would make this edge (see picture)? If not, how would you do it? Thanks.
jancar is offline
post #2 of 8 (permalink) Old 10-04-2016, 01:35 PM
kp91's Avatar
First Name: Doug
That would be fairly easy to do with a rabbetting bit set.
http://www.woodcraft.com/Product/129...Set-12-SH.aspx
Use the larger bearing first, then switch to a smaller one for the second cut
Could also be done with a table saw and a flat tooth blade if only on a straight edge
there are similar ones that do it in one pass, but you'll have to verify the profile
http://www.rockler.com/twin-step-ogee-bit-oe833
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #3 of 8 (permalink) Old 10-04-2016, 02:14 PM
Welcome Jancar to the forums..
the bit you are looking for is called a stepped picture frame rabbeting bit...
you will need to a adjust the bearing size to get the profile dimensions you are after...
gjackson52 likes this.
post #4 of 8 (permalink) Old 10-04-2016, 04:28 PM
Honored Member
First Name: pat
Can be done with same cutter.
For example Whiteside 2901.
Set first step to 1/4 x 1/8.
Raise cutter x 1/8, riding rabbet, and repeat.
Quillman is offline
post #5 of 8 (permalink) Old 10-04-2016, 06:22 PM Thread Starter
Thanks for the replies! I was hoping to do it in one pass, but the stepped bits don't seem to come in these dimensions. I'll try to do it with the rabbeting bits.
jancar is offline
post #6 of 8 (permalink) Old 10-04-2016, 07:11 PM
this bit will do it in one pass if you change the bearing w/ an increased OD of ½'' which will reduce the horizontal depth of cut ¼''...
post #7 of 8 (permalink) Old 10-04-2016, 07:56 PM
old55's Avatar
First Name: Ross
Welcome to the forum Jancar.
Ross,
old55 is online now
post #8 of 8 (permalink) Old 10-05-2016, 02:02 AM
Welcome Jancar. It can also be done on a table saw in 4 passes which is faster if you have a bunch to do or is cheaper if you only have one to do.
The use of a Router table as a Profile Copier neville9999 Jigs and Fixtures 4 12-06-2012 11:44 AM
How to Make a Picture Frame learnexperience Table-mounted Routing 10 09-24-2011 04:48 AM
Thanks for a great forum tmutchf New Member Introductions 9 03-11-2010 04:43 AM
