Roundover bit for shallow edge - - Router Forums
 1Likes
  • 1 Post By harrysin
post #1 of 10 (permalink) Old 10-28-2016, 11:27 PM Thread Starter
UPO
First Name: Richard
Default Roundover bit for shallow edge -
Trying to find a 1/4 inch round over bit that can profile the INSIDE lip of a shallow tray or box where the inside face side is 90deg to the upper surface.
The 1/4 inch I have is just too tall / deep with the bearing so the bit bottoms out well before the bit gets even close to the edge that I am wanting to round over.
the normal 1/4 inch RO bit used in the table is fine for the OUTER edges as the bearing can do as it should on the outer surface as height is not an issue.
Is there a "short" profile bit available ? Really dont want to have to sand the profile as quite a lot to do and very hard to get a consistent profile that way as I mostly use hardwoods for these pieces.
UPO - Richard
UPO is offline
post #2 of 10 (permalink) Old 10-28-2016, 11:29 PM Thread Starter
UPO
First Name: Richard
One of the thought I have had but NOT tried is to use a second larger opening template and use a top mounted bearing - any thoughts ??
UPO - Richard
UPO is offline
post #3 of 10 (permalink) Old 10-29-2016, 12:03 AM
I am not sure what you are trying to achieve, but I have both a Dremel and a trim router set up with an 1/8" bit that has a brass pilot to give small round overs to the edges of my work. I think it is a 1/16" radius.
Infinity and MLCS both carry these bits if I recall right, and the Dremel site at CPO outlets has the Dremel set. They are 1/4" shank,except the Dremel is 1/8" shank.
Herb Stoops is online now
post #4 of 10 (permalink) Old 10-29-2016, 12:18 AM
An ovolo bit may be what you are looking for. You could install a bearing on the shaft or you could use it with a guide bushing since you would have to use a template with either method. https://www.thetoolstore.ca/viewItem.asp?idProduct=1769
post #5 of 10 (permalink) Old 10-29-2016, 03:06 AM
TWheels's Avatar
Richard, @Cherryville Chuck saw this thread before I did so he gets credit for suggesting an Ovolo bit, with a template guide or shaft bearing. I am surprised you specify 1/4 inch radius instead of, say 6 mm or 6.35 mm radius. I checked the Carbatec web site and wonder if this bit close enough:
https://www.carbatec.com.au/routing-...o-bit-1-2s-cmt
or the 6.35 mm radius bit
https://www.carbatec.com.au/routing-...&PageProduct=1
I Hope to Be the Person My Poodles Believe I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is offline
post #6 of 10 (permalink) Old 10-29-2016, 07:34 AM
First Name: Art
Is it possible to do the routing before the top is assembled? Perhaps stopping short of the corners and doing those with sandpaper.
mgmine is offline
post #7 of 10 (permalink) Old 10-29-2016, 08:29 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
The right hand round-over face cutter shown, in combination with a template guide and template is the way that I would go.
TWheels likes this.
Harry
harrysin is offline
post #8 of 10 (permalink) Old 10-29-2016, 06:57 PM Thread Starter
UPO
First Name: Richard
Many thanks for the responses - I had been over focused on the bearing guide issue and had not thought outside that self created mental box so to speak.
The ovolo bit certainly seems the way to go - just need another template with the correct off set to suit the guide bush - at the moment I am routing the end grain using irregular shaped natural edge Australian Ironbark hardwood , I trace the outline of the stock then draw in the wall thickness required then transfer to the template material then cut out with the jigsaw - now I will just need to mark the new offset, jigsaw off the few mm offset material and ready to do the roundover - really simple solution once the bit solution was provided.
Thanks again
UPO - Richard
UPO is offline
post #9 of 10 (permalink) Old 10-29-2016, 07:27 PM
Thumbs up
That was going to my suggestion, but you have to get up early to beat Harry.......
Sydney, Australia
jw2170 is offline
post #10 of 10 (permalink) Old 10-29-2016, 08:38 PM
TWheels's Avatar
That bit is the one I know as ovolo, but there are companies that call it a round over, and what I always called a round over bit, with a bearing (second right in Harry's picture) is called corner rounding. Certainly the picture helps.
Different companies, different nomenclature = confusion
TWheels is offline
Is there a router bit to make this edge? jancar Router Bits - Types and Usage 7 10-05-2016 02:02 AM
Edge Banding Router Bit Sets patlaw General Routing 15 02-02-2016 01:10 PM
3/4 inch pine, what roundover bit? Karter Router Bits - Types and Usage 9 02-21-2011 04:57 PM
1"x2" pine, what rounding edge router bit do I need for a flush edge? annmariehawkins Router Bits - Types and Usage 5 12-04-2010 12:00 PM
3/4" Radius roundover bit with 1/4" shank chrisogrady Router Bits - Types and Usage 8 04-01-2005 08:08 PM
