Correct Router Speed - Router Forums
 2Likes
  • 2 Post By mgmine
post #1 of 7 (permalink) Old 11-04-2016, 05:15 AM Thread Starter
Default Correct Router Speed
I am trying to make boxes out of Sapele using a lock mitre bit. Can anyone tell me the correct speed to use, particularly when routing across the grain. I am use stock milled to 10.5mm thick. Any help will be gratefully received.
John Selwyn
John Selwyn is offline
post #2 of 7 (permalink) Old 11-04-2016, 07:09 AM
First Name: Art
Typically the router will give you a speed of 1-10 and not actual rpm's. But even if yours gives you the rpm's it still would only be a guide. The best speed is the one that gives you the cleanest cut so you would have to test the cuts on some scrap wood. The only time I change my speed is if I am using a very large paneling bit or a very small straight bit. Other than that what ever speed sounds right and cuts right is where I leave it. There are recommendations given all over the internet but just use your ears and you should be fine.
John Selwyn and MEBCWD like this.
mgmine is offline
post #3 of 7 (permalink) Old 11-04-2016, 09:33 AM Thread Starter
Thanks Art, I'll do some test runs.
post #4 of 7 (permalink) Old 11-04-2016, 10:15 AM
JOAT's Avatar
First Name: Theo
All my routers are one speed, and I have no idea what that speed is. But, depending on various results, I feed the wood at varying speeds. I mostly use 1/2" plywood, so my results will likely be different from you. With end grain, I take very light cuts, slowly; that usually produces good results for me.
JOAT is online now
post #5 of 7 (permalink) Old 11-04-2016, 10:32 AM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
if youre routing across the grain, you must use a piece of scrap to push it through. If you just run the good wood across the end will splinter. Use any scrap wood tight to the finished piece and let the bit cut into the scrap fully before pulling away.
My table router is one speed and I havent had a problem with that yet. If I had a speed adjuster, i would run it at about 3 thirds full speed normally.
sunnybob is offline
post #6 of 7 (permalink) Old 11-04-2016, 11:44 AM
Nickp's Avatar
First Name: Nick
MLCS reports speed at no more than 18,000RPM for that bit. If you have a good horsepower router, you could try slower but watch your feed rate. If it struggles, bring speed back up or slow your feed rate. If you start to get chatter or "bouncing" or rough cut on the piece, bring your speed back up...try to stay below that 18,000 though...
Some will recommend even slower...the slower you can run it and get good results, the better...good luck...
Nick
Nickp is offline
post #7 of 7 (permalink) Old 11-04-2016, 12:39 PM
There are some router bit speed charts on this page for a guide to start from. Then follow the other suggestions. https://ca.images.search.yahoo.com/y...=yhs-fh_lsonsw
Making a Flat-Bottomed Candy Dish using a Router learnexperience Table-mounted Routing 2 12-09-2018 08:51 AM
Using Your Router For The First Time learnexperience General Routing 0 07-23-2011 09:20 PM
Router Speed Control Barreller General Routing 15 06-06-2009 03:17 PM
Router Speed Guide CanuckGal Starting Off 9 12-25-2008 04:52 PM
