Router Bit Sharpening Tools - Router Forums
post #1 of 11 (permalink) Old 11-08-2016, 07:34 AM Thread Starter
Contributor of the Month
Default Router Bit Sharpening Tools
I've got some router bits that could use some touch-up/sharpening. What's a good source to buy the sharpening tools and what do I need to buy?
JIMMIEM is offline
post #2 of 11 (permalink) Old 11-08-2016, 08:01 AM
hawkeye10's Avatar
First Name: Don
Jim I watched this video and found it interesting.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #3 of 11 (permalink) Old 11-08-2016, 08:32 AM Thread Starter
https://www.youtube.com/watch?v=o4AtrNXR5Iw
Thank You. I just watched it. I found some sites that sell the Trend Sharpening supplies.
JIMMIEM is offline
post #4 of 11 (permalink) Old 11-08-2016, 10:26 AM
tvman44's Avatar
First Name: Bob
I use the method hawkeyes suggested and it works well.
Papa Bob
Using a couple of old Craftsman routers & a Bosch 1617EVSPK & a Dewalt DWP611PK Routers in SW Louisiana.
tvman44 is offline
post #5 of 11 (permalink) Old 11-08-2016, 11:10 AM
Same as above except I use the ones mounted on a plastic base like you find at PA up here or HF down there.
post #6 of 11 (permalink) Old 11-15-2016, 02:16 PM Thread Starter
Which grits do you recommend I get? Trend has a 2 sided card with 300 and 600 grits. HD has a 600 grit diamond paddle file.
JIMMIEM is offline
post #7 of 11 (permalink) Old 11-15-2016, 03:46 PM
hawkeye10's Avatar
First Name: Don
In the video he is using 600 grit. You don't want to sharpen router bits to sharp because carbide is very hard and brittle. If the edge is to sharp or you might say thin it will break off under normal use and leave a chip.
post #8 of 11 (permalink) Old 11-15-2016, 04:28 PM Thread Starter
The info says to use the 300 grit on tools that are pretty worn.....wondering if the 300 will work or if pro sharpening is needed at that point.
JIMMIEM is offline
post #9 of 11 (permalink) Old 11-15-2016, 05:31 PM
The better bits usually mention something about 600 grit sharpening but that is power sharpening and if power sanding is any indication when compared to doing it by hand then the power sharpening at that grit will be finer than you can do with a 600 grit hone. I would go to the 600 for the final like the vid said to do. Pro sharpening is when it still doesn't cut that good even after you try yourself. Chances are by that time that the geometry is off and maybe the relief angle on the back side of the edge. That relief angle is pretty critical for getting a good finish and it's something that is usually not recommended to try by hand to retouch.
post #10 of 11 (permalink) Old 11-15-2016, 05:44 PM
tvman44's Avatar
First Name: Bob
I use the 600, for whatever that is worth.
Papa Bob
tvman44 is offline
New to the forum Zwervertje57 New Member Introductions 7 06-06-2015 11:10 AM
New to forum. archie2401 New Member Introductions 13 12-08-2014 07:21 AM
New Member! bosswood New Member Introductions 8 10-02-2014 08:18 PM
