Baseboard heat covers - Router Forums
 4Likes
  • 2 Post By Herb Stoops
  • 1 Post By Herb Stoops
  • 1 Post By Jgrass
post #1 of 10 (permalink) Old 11-24-2016, 09:51 PM Thread Starter
Default Baseboard heat covers
Looking for some advice. I built some simple baseboard covers for a basement bathroom out of mdf but for the living room I want to class them up a bit. What bit would I use to create the design on the face of this example?
Jgrass is offline
post #2 of 10 (permalink) Old 11-24-2016, 11:12 PM
J , just guessing but that looks like a stamped metal or molded plastic cover. My guess it would be rather involved to duplicate in wood in one piece. Maybe a CNC? otherwise the raised panel portion would have to be built in pieces like a panel door and then assembled into a single unit.
Semipro and RainMan 2.0 like this.
Herb Stoops is offline
post #3 of 10 (permalink) Old 11-25-2016, 12:17 AM
Welcome to the forum J. Is that just an air register that the cover hides?
post #4 of 10 (permalink) Old 11-25-2016, 03:14 AM
raised panel door sets/bits..
freudtools - Search Results for cabinet bit set
BTW.... welcome oh nameless one... to the forums...
File Type: pdf PremierAdjustableRailandStilePoster.pdf (432.3 KB, 54 views)
post #5 of 10 (permalink) Old 11-25-2016, 05:55 AM
paduke's Avatar
Welcome to our forum No question too dumb around here
you want a faux raised panel bit Door & Window :: Faux Panel or google faux raised panel router bits
here is a thread http://www.routerforums.com/router-b...anel-bits.html
paduke is offline
post #6 of 10 (permalink) Old 11-25-2016, 11:58 AM
That is very similar, Bill, but not the same pattern with the long bevel on the inner side. The only way I can think of duplicating is in separate pieces.
But your solution would be good way to do it in a one piece board and have the same effect but a little different pattern. If I were to do that I would use your suggestion. If there were several to do a good template a Faux bit with a bottom bearing in a plunge router should work. Would reqiure some hand work in the corners, I suspect.
Cherryville Chuck likes this.
post #7 of 10 (permalink) Old 11-25-2016, 12:50 PM
I agree with Herb. A reasonably precise copy requires separate pieces as the profile on the outer edge of the raised panel profile is not a duplicate of the inner profile.
post #8 of 10 (permalink) Old 11-25-2016, 01:38 PM
paduke's Avatar
Agreed there will be rounded corners. OP could use some choices
paduke is offline
post #9 of 10 (permalink) Old 11-25-2016, 08:27 PM
old55's Avatar
First Name: Ross
Ross,
old55 is offline
post #10 of 10 (permalink) Old 11-26-2016, 08:48 AM Thread Starter
Thanks, I think that faux bit will work perfectly. I have a pic of another less intricate option that looks like it's exactly what was used.
Herb Stoops likes this.
Jgrass is offline
Win GREE Rio 9,000 BTU Ductless Mini Split Heat Pump Air Conditioner From ComfortUp Router Forums Featured Topics 319 06-16-2016 03:47 PM
Well looks like I'm working in a cold shop again this winter RainMan 2.0 Lobby 221 10-26-2015 08:31 PM
Heat and Routing Mike Featured Topics 18 10-09-2015 11:50 AM
Trying to beat the heat Glenmore Lobby 7 07-16-2008 01:14 PM
material for radiator covers peacefrog Project Plans and How To 4 02-21-2008 12:52 PM
