Bullnose Bit - Router Forums
 6Likes
post #1 of 15 (permalink) Old 01-03-2017, 01:53 PM Thread Starter
inkslinger's Avatar
Default Bullnose Bit
I'm new here an I just bought my first router and it just happens to be a used one I won from Ebay a Bosch 1617 EVS fix/plunge kit I pick up for $123. I have been doing a lot of reading on routers .
I would like to get some bull nose bits for 1/4 , 1/2 and 3/4 inch wood and would like to know what size bit do I need to look at? The router only has one collet an it looks to be a 1/4 inch {only cause it has 4 1/4 inch bits in the case} I did order a 1/2 in collet for it just in case.
inkslinger is offline
post #2 of 15 (permalink) Old 01-03-2017, 02:01 PM
Semipro's Avatar
First Name: John_*
Hello and welcome to the router forum.
Stick with 1/2 shank bits when possible, Carbide tips
Use the search bar, number articles on bits types and brands
Watch
vchiarelli likes this.
Thank You John
Semipro is online now
post #3 of 15 (permalink) Old 01-03-2017, 08:15 PM
The 1617 is one of the best routers ever. You can find half inch and metric collets for it just by googling. The Bosch tools website lists them and they can be ordered on Amazon.
Try this video:
The size you use depends on the look you're trying to produce. A roundover could be done in passes with a quarter round bit.
Roy Drake likes this.
post #4 of 15 (permalink) Old 01-03-2017, 09:11 PM
Here are some pictures of bullnose bits and what they can produce. Sometimes you might use several bits to produce an interesting or novel edge. Notice the subtle differences when you, say, use a half inch bullnose on a 3/4 edge, vs a 3/4 bit on a 3/4
edge, or you can stack a small bullnose (a bead) above or below a larger one. Or do a second piece and glue it to the basic edge.
Name:	bullnose bit 1.jpg
Name:	Bullnose medium.jpg
post #5 of 15 (permalink) Old 01-03-2017, 09:17 PM
old55's Avatar
First Name: Ross
Welcome to the forum.
Ross,
old55 is offline
post #6 of 15 (permalink) Old 01-03-2017, 09:28 PM
Oh yes, welcome, glad you could join in the festivities.
post #7 of 15 (permalink) Old 01-03-2017, 10:09 PM
Welcome to the forum Ink. Keep in mind that bullnose bits must be used with either and edge guide or with a fence on a router table. When you set it the center of the bit's curve must be even with the guide or fence or behind them. It can't be in front of them. The easiest way to set one flush with a guide or fence is to use a round dowel in the curve and flush the dowel to the fence. Because of the issues with setting and using a bullnose many prefer to use a round over bit instead and rout from both sides.
post #8 of 15 (permalink) Old 01-05-2017, 11:16 PM Thread Starter
inkslinger's Avatar
So in order to use a bull nose bit is on a table ? Not planning on one just yet. So maybe a round over bit , I can clamp down and flip it over right?
Will just got my router from ups today I was amaze of it size, sure enough it only had a 1/4in collet was glad I order the 1/2in . I will post some pic's soon , it came with 4 1/4in bit's but don't know what they do, I took it apart and clean every thing an fire it up to make sure it work fine. Nice! Thanks for the info I've been looking at those utube's and doing some more reading .
post #9 of 15 (permalink) Old 01-06-2017, 12:13 AM
Any bit that doesn't have a bearing to guide it along an edge has to use some other method for guiding it. An edge guide or fence are good for straight lines. A template bushing or bearing guide will follow curves. The one exception to this is if you are free hand routing such as making a sign. That usually requires a little practice and not routing very deep.
post #10 of 15 (permalink) Old 01-06-2017, 09:54 AM Thread Starter
inkslinger's Avatar
Here is the pic of my 1/4in bit's {where can one fine what these bit's will do?}
Selecting the router bit for a given application Chris_L Router Bits - Types and Usage 4 02-13-2012 08:49 AM
Sears router bit description gary smyth Router Bits - Types and Usage 4 07-01-2011 05:15 PM
Router Bit Set for Raised Panel Doors Hoss McGr Table-mounted Routing 8 10-17-2009 04:17 PM
Router bits speedo Router Bits - Types and Usage 18 10-08-2009 03:17 PM
How to do a bullnose with a roundover bit? LBrandt Router Bits - Types and Usage 2 06-10-2006 06:10 PM
