Pattern/Flush Trim Bit for Routing Rabbets? - Router Forums
 9Likes
  • 5 Post By Stick486
  • 1 Post By Cherryville Chuck
  • 1 Post By Quillman
  • 1 Post By scottgrove
  • 1 Post By DesertRatTom
post #1 of 6 (permalink) Old 01-03-2017, 07:54 PM Thread Starter
First Name: David
Default Pattern/Flush Trim Bit for Routing Rabbets?
A couple years ago I got a free resaw job on some hardwoods that were gifted to me. The result was a quantity of wood less than the 3/4" thickness I wanted. I would like to make some small boxes with the wood which is 1/4"-5/8" thick. Can I make satisfactory rabbet joints using a 1/2" trim bit in my Bosch Colt or would I be better off buying a rabbeting bit?
harpone is offline
post #2 of 6 (permalink) Old 01-03-2017, 08:36 PM
buy the rabbeting w/ a bearing set or use your table saw...
post #3 of 6 (permalink) Old 01-03-2017, 10:01 PM
Dave a flush trim bit won't work. A pattern bit or a bearing guided mortising bit would but a rabbeting set would work better (easier). As Stick suggested I do most of my rabetting on my TS because it is so much faster.
harpone likes this.
post #4 of 6 (permalink) Old 01-04-2017, 08:41 AM
Honored Member
First Name: pat
A flush trim bit will work but it's conditional.
If the bearing is on the shank, it's essentially a straight bit
and will cut rabbets on the router table. And it can be done with a templet with a hand router. Again if the bearing is on the shank, not on the end of the tool.
The radial design of a rabbet bit can't be beat for stiffness and cut-efficiency. A straight bit will struggle, especially one with a 1/4" shank.
The bigger problem is the cutter hole in your PR-20 base plate.
Most rabbet bits won't fit through the opening. Moreover, you're stuck with 1/4" shanks, a real handicap.
Would get a small 1/2" router for those apps the Colt won't cover.
harpone likes this.
Quillman is offline
post #5 of 6 (permalink) Old 01-04-2017, 09:57 AM
First Name: Scott
I'd use my router table with a fence. No need to spend the money on another bit unless your looking for an excuse to.
Enjoy
harpone likes this.
scottgrove is offline
post #6 of 6 (permalink) Old 01-04-2017, 08:29 PM
If you're going to use a router, you need a 1/2 inch shank, not a 1/4 incher. I also like having a bit with interchangable bearings is a real bonus. I always prefer to use a router table for such cuts because it is very difficult to hold the router stable on an edge even with an edge guide. I also like using a table saw for this purpose, very fast, and you can do it with any blade that gives you a clean bottom. Even with a coarser blade, you can always smooth the bottom of the rabbet with a plane.
harpone likes this.
Conquoring The Miter Lock Bit Jerry Bowen Tools and Woodworking 9 10-09-2016 01:43 PM
Tapered trim bit freddiemerion New Member Introductions 5 11-17-2013 03:01 AM
OMG, top bearing trim bit frustration vindaloo Router Bits - Types and Usage 4 08-15-2013 07:25 PM
is it safe to use a straight bit like a flush trim bit? achoox4 Router Bits - Types and Usage 12 04-11-2013 11:25 AM
bit speeds, something to think about reible Router Bits - Types and Usage 0 10-19-2004 09:20 PM
