I Soaked A Carbide Bit In Simple Green - Router Forums
 10Likes
post #1 of 27 (permalink) Old 01-15-2017, 08:13 PM Thread Starter
Contributor of the Month
Default I Soaked A Carbide Bit In Simple Green
After I had soaked a solid carbide bit in regular Simple Green I read that this is a no-no....supposedly leeches the carbide from the bit. Simple Green does have another product which is ok to use.
The bit lost is shiny color and I'm wondering if it is unsafe to use.
Anybody know anything about this?
JIMMIEM is offline
post #2 of 27 (permalink) Old 01-15-2017, 09:50 PM
First Name: Clay
I have been using simple green on bits and blades for years with no problems. I don't soak them just use a brass brush and the solvent, then blow them with air and oil them. I have read you are supposed to use simple purple for carbide.
fire65 is offline
post #3 of 27 (permalink) Old 01-15-2017, 11:08 PM
what ever you say...
post #4 of 27 (permalink) Old 01-16-2017, 10:41 AM
Jim; there was at least one thread running here a while back, on Simple Green products.
http://www.routerforums.com/router-b...tml#post603137
The short story is that Simple Green themselves warned against soaking carbide in their regular product.
They recommended their Precision Aircraft Cleaner for soaking carbide tools.
DaninVan is offline
post #5 of 27 (permalink) Old 01-16-2017, 12:06 PM
First Name: Clay
I should have been clearer. I am not advocating using simple green, use the purple. I was just saying I have not had a problem, but I now use the PURPLE, better yet order the cleaning kit from Rockler.
fire65 is offline
post #6 of 27 (permalink) Old 01-16-2017, 12:10 PM
Trend bit cleaner works and is harmless to you and the bit. I believe CMT makes a cleaner also.
post #7 of 27 (permalink) Old 01-16-2017, 12:18 PM
trend is some good stuff...
post #8 of 27 (permalink) Old 01-16-2017, 12:25 PM
tvman44's Avatar
First Name: Bob
I have been using Simple Green or Mean Green, I soak for a couple of minutes and then use a brass bristle brush from Harbor Freight, rinse then spray with WD40 and it works great. Have used this method for several years on my carbide saw blades and now on my router bits.
Papa Bob
Using a couple of old Craftsman routers & a Bosch 1617EVSPK & a Dewalt DWP611PK Routers in SW Louisiana.
tvman44 is offline
post #9 of 27 (permalink) Old 01-16-2017, 01:21 PM
First Name: Earl
Trend. Tried the Rockler, no comparison. Going back to Trend. If I were to use some of the household products or alchemy methods I doubt i'd save a dollar or two per year (and I clean a lot) so...Trend.
earl
greenacres2 is offline
post #10 of 27 (permalink) Old 01-16-2017, 03:27 PM
Bob; the issue isn't that it doesn't work, it does! The problem as stated by the manufacturer...see my link in my previous comment...is that it corrupts the Carbide!
Since even Simple Green makes a safe alternative, recommended by them, why risk damaging your Carbide?
DaninVan is offline
How big of a problem will I have with this Forstner bit? Barry747 Tools and Woodworking 8 04-05-2016 09:46 AM
Getting started with router bits Mike Router Bits - Types and Usage 26 02-22-2015 02:23 PM
Two wrench method- one wrench router Delta6mike General Routing 68 03-26-2012 09:25 AM
Simple bit for a nice drawer face. jmurph Router Bits - Types and Usage 2 08-29-2010 08:03 PM
Router Bit Set for Raised Panel Doors Hoss McGr Table-mounted Routing 8 10-17-2009 04:17 PM
