MLCS Router Bit Quality - Router Forums
 11Likes
  • 1 Post By JIMMIEM
  • 5 Post By Stick486
  • 1 Post By Cherryville Chuck
  • 1 Post By bryansong
  • 2 Post By Herb Stoops
  • 1 Post By Gaffboat
post #1 of 8 (permalink) Old 02-04-2017, 08:16 AM Thread Starter
Contributor of the Month
Default MLCS Router Bit Quality
Just wondering where MLCS bits come in on the quality scale? I have mainly used Infinity Bits.
bryansong likes this.
JIMMIEM is offline
post #2 of 8 (permalink) Old 02-04-2017, 08:22 AM
For those that think w/ their wallets.... greatest thing since sliced bread...
for those that prefer quality... using them just once was enough...
post #3 of 8 (permalink) Old 02-04-2017, 08:29 AM Thread Starter
Thank You....it's the recycle bin for the MLCS catalogue.
JIMMIEM is offline
post #4 of 8 (permalink) Old 02-04-2017, 10:46 AM
Jim, Infinity is an excellent choice. They score very high. MLCS not so good as Stick says. This is a bit test that is 10 years old now and things may have changed some but I expect that it is still pretty reliable. http://www.whitesiderouterbits.com/t...routerbits.pdf One of the surprises for me was that Rockler did well. I would have expected them to be close to MLCS.
If you plan on using a bit a lot then it makes sense to get a good one. Roundovers and straight bits you might as well buy the best. They aren't that expensive to start with. Some architectural molding bits can be really expensive and you may use them very rarely so it's hard to hard to justify shelling out over $100 for one. In those cases it may make more sense to go with something like Yonico (Precision Bits) for under $30.
post #5 of 8 (permalink) Old 02-04-2017, 11:35 AM
bryansong's Avatar
First Name: bryan
Charles, I have been wondering the same thing as Jim. Thanks for the link to the review, I've save it.
Jim, thanks for asking the question.
Bryan
Cherryville Chuck likes this.
bryansong is offline
post #6 of 8 (permalink) Old 02-04-2017, 12:49 PM
I use some MLCS bits for occasional cuts. They aren't that bad. If I was doing production work ,I wouldn't use them, but like chuck said,doesn't justify buying a $100 bit for occasional cuts.
Most of my bits are Infinity or Freud,or Rockler.
kp91 and artman60 like this.
Herb Stoops is online now
post #7 of 8 (permalink) Old 02-05-2017, 09:14 AM
richjh's Avatar
First Name: Rich
I have the MLCS 66 piece set that I purchased a few years ago. Every bit I have used has worked as well as my more expensive bits. I am an occasional woodworker so these bits work for me. I would invest in high quality bits if I was doing a lot of routing. I have roundover bits from CMT that I have been using for many years and they still work great.
Rich
Basically, a tool is an object that enables you take advantage of the laws of physics and mechanics in such a way that you can seriously injure yourself - Dave Barry
richjh is offline
post #8 of 8 (permalink) Old 02-05-2017, 11:31 AM
Gaffboat's Avatar
First Name: Oliver
I don't do production work and I seldom rout a lot of hardwoods so I've had no issues with the MLCS bits I've purchased. Having said that, I do prefer the bits made by Whiteside or CMT.
Herb Stoops likes this.
Gaffboat is offline
Making a Flat-Bottomed Candy Dish using a Router learnexperience Table-mounted Routing 2 12-09-2018 08:51 AM
Intro and question john spies New Member Introductions 20 12-08-2018 11:08 AM
Selecting the router bit for a given application Chris_L Router Bits - Types and Usage 4 02-13-2012 08:49 AM
MLCS Circle Jig larryc Table-mounted Routing 3 01-30-2012 10:44 PM
Ridgid Router Easy Above Table Bit Change shawnpatt Table-mounted Routing 1 03-06-2009 04:58 PM
