Makita 3709 router used forms to scroll work - Router Forums
 3Likes
  • 1 Post By Quillman
  • 1 Post By AndyL
  • 1 Post By old55
post #1 of 9 (permalink) Old 03-06-2017, 04:03 PM Thread Starter
Default Makita 3709 router used forms to scroll work
Hello, I am trying to figure out what type of router bit can cut out projects in mdf. I will attach a picture that i have found online but can't figure out what type of bit the person is using.
Fraggle is offline
post #2 of 9 (permalink) Old 03-06-2017, 04:23 PM
are you talking a full cut out???
post #3 of 9 (permalink) Old 03-06-2017, 04:47 PM Thread Starter
Yes taking full cut.
Fraggle is offline
post #4 of 9 (permalink) Old 03-06-2017, 05:06 PM
Honored Member
First Name: pat
Forget it. No way will that little trimmer cut through MDF with any cutter.
A plunge trimmer (compact) will do it in stages but not one pass.
A cutter as skinny as 1/4" will do it in stages, say 4/1/4".
You will have the mess of the century without perfect dust pickup.
Fraggle likes this.
Quillman is offline
post #5 of 9 (permalink) Old 03-06-2017, 05:46 PM Thread Starter
Just from looking at the picture the cut line only looks to be about 1/8" thick. Not 1/4". Just wondering what kind of bit they used.
Fraggle is offline
post #6 of 9 (permalink) Old 03-06-2017, 06:00 PM
First Name: Andy
Maybe it's something like one of these Dremel cutting bits, if the router has a 1/8" collet.
https://www.dremel.com/en_US/product...se-cutting-bit
But like Pat said, the dust problem is going to be pretty bad.
Fraggle likes this.
AndyL is offline
post #7 of 9 (permalink) Old 03-06-2017, 06:35 PM Thread Starter
That's a possibility Andy. Thanks.
Fraggle is offline
post #8 of 9 (permalink) Old 03-06-2017, 08:02 PM
old55's Avatar
First Name: Ross
Welcome to the forum Fraggle.
Fraggle likes this.
Ross,
old55 is offline
post #9 of 9 (permalink) Old 03-07-2017, 02:22 PM
Wildwood's Avatar
Country: South Africa
First Name: Rob
Hi Fraggle, and welcome to the forum. Some years ago I had to cut out an elaborate scene in 12mm yellowwood, a local wood that's not very hard. I used a jig-saw with a scroll blade to rough it out, and then a Dremel Trio (which is something like a small router) with an 1/8" solid carbide bit to get more detail - it was very hard going trying to control the direction of the Dremel, and I had to take small bites at a time - I eventually got a reasonable result, but not without a lot of aggravation. 3/4" MDF would have probably broken the solid carbide bit.
Wildwood is offline
Newbie in using a Router..... Andron General Routing 6 03-20-2013 02:20 PM
Quick fix for router work. jigman Portable Routing 12 02-22-2010 04:55 PM
