Sommerfeld Router Bits...Bearing Sizes - Router Forums
 4Likes
  • 1 Post By Semipro
  • 1 Post By Stick486
  • 2 Post By Stick486
post #1 of 8 (permalink) Old 03-17-2017, 10:37 PM Thread Starter
Default Sommerfeld Router Bits...Bearing Sizes
I'm a bit of a newbie to router tables and cabinetmaking but I have decided to jump into it with both feet.
I purchased the Sommerfeld cabinetmaking set. It includes router, table, three sets of bits, etc. Just started practicing with it today, boy am I going to need a lot of practice.
I would like to know what the different sized bearings that come in the sets are for. I assume that they will create deeper or shallower cuts but I usually get into trouble when I assume.
I am also wondering about the 'not having to adjust height of each bit once one bit in set is adjusted'. In some of the literature, it states that the pattern bit may have to be adjusted to meet the cove cutter. They also say that the panel cutter may have to be adjusted to fit the pattern cutter. It states that you may need to practice on several scrap pieces till you get it right.
Would appreciate any feed back.
Thanks in Advance!
mhtmtree is offline
post #2 of 8 (permalink) Old 03-17-2017, 11:19 PM
Mike here is an example of what changing the bearing can on a roundover bit. With one bearing you get the roundover. With a smaller bearing you get an edge profile. You can get a rabbeting kit like this too. One bit but different size bearings or rub collars that slip on the bearings.
Freud Tools | 3/8" Radius Rounding Over Bit (Quadra-Cut)
Freud Tools | flush, 1/8",1/4",5/16",3/8",7/16",1/2" Depth Rabbeting Bit with Bearings
The various bearings give you different depths of rabbet.
post #3 of 8 (permalink) Old 03-17-2017, 11:37 PM
Semipro's Avatar
First Name: John_*
Use utube look for Marc Sommerfeld videos they take you how to use all the cabinet making bits
Ed3443 likes this.
Semipro is offline
post #4 of 8 (permalink) Old 03-17-2017, 11:49 PM
Hi, I really like the Sommerfeld stuff. Several things occur to me. First, the matched sets don't require adjustment other than the first height setting because all the shanks are exactly the same length.
Since you're not supposed to bottom out the shank on a router, you place a half inch, common rubber grommet (supplied with sets) in the bottom of the collet. That way all subsequent bits are seated exactly the same.
Next, notice that the finished side always goes down, so the cuts are all relative to the top or finished side of the work pieces. For this reason, you must make sure all our work pieces are the same thickness. If you are buying big box wood, that's pretty easy to manage, but you have to take care to pick pretty flat pieces, maybe one in 10-20 pieces will pass muster.
The solution is really to buy extra thick stock and mill it down to be straight, flat and just the right thickness. That will require buying wood carefully and/or eventually buying a jointer and planer. These tools may or may not be necessary.
If you mill your wood yourself, you have to use it fairly soon after milling. That process often releases stresses in the wood so it will warp it beyond usability. You should make sure the stock spends a few days in your shop area to aclimatize.
Sommerfeld makes a star shaped EasyJig for setting height on its bits. You turn a dial on the jig to the thickness of the stock, and adjust the height of your bit using the jig. From then on while using the sets, all other bits are the correct height.
They make a red version of this for setting up Freud matched sets. Freud bits are fine, I just prefer Sommerfeld's. Everyone has their preferences on blades and bits.
I went ahead and purchased the entire Sommerfeld video sets, although they are all on YouTube. I like being able to sit down and watch with any stops and starts.
Plywood is a wonderful thing, but there's a whole range of types, ranging from the Chinese stuff you get at the big box stores. Ok for, well, really coarse work. Then there is Baltic Birch, which has 13 layers and no voids between layers. Comes in 5ft square sheets, usually very flat because of all those layers, and cuts with very little splintering. Ply is often used for the body (carcus) of cabinets, and sometimes a nice grade of cheaper ply will do for that purpose.
One thing I suggest you check out soon is pocket screw joinery. It is a really strong and easy, particularly for face frames and squaring up boxes. The Kreg K4 kit is what I use, but there is a later model as well. Use the square headed screws rather then the Phillips heads. Use coarse threads for soft wood, fine threads for hardwoods.
This may be more than you wanted to know for now, and you can do a lot with what you find at the big orange box. Just depends on what you want to make.
Have fun with this. it is very satisfying.
DesertRatTom is online now
post #5 of 8 (permalink) Old 03-18-2017, 12:11 AM
bearing set can have 2~3 bearings or as many as on up to 30 bearings... (SAE and Metric sets combined - but what for)
a 5 or 6 bearing set will cover a lot of territory...
better bearings won't leave you hanging or wanting... and less likely to screw up your project...
BTW.. those Freud quadra cuts are sweet...
see if this helps...
post #6 of 8 (permalink) Old 03-18-2017, 12:14 AM
don't know if you already got these... but here goes anyways...
bit of collected knowledge..
File Type: pdf R5 Climb-Cutting Versus Chip-Cutting.pdf (176.1 KB, 76 views)
File Type: pdf Routing for Beginners - Lesson - 3.pdf (856.1 KB, 62 views)
Ed3443 likes this.
post #7 of 8 (permalink) Old 03-18-2017, 12:16 AM
I know you want more...
Name:	GUIDE BUSHINGS.jpg
Name:	GUIDE BUSHING - TEMPLATE.jpg
Ed3443 and RainMan 2.0 like this.
post #8 of 8 (permalink) Old 03-18-2017, 11:04 AM
TWheels's Avatar
Thanks in Advance!
Hi Mike, Welcome to RouterForums
To make it all simple, your assumption about the role of the different sized bearings is correct.
Also, Sommerfeld Tools is very proud that all bits in its sets are height adjusted as sold, so the height adjustment for eacb bit you refer to is not necessary; with Sommerfeld sets adjust the height of the first bit for the task then all others are set.
Personally I find Sommerfeld to be a superb source of high quality bits, but they have a relatively limited set of profiles.
I Hope to Be the Person My Poodles Believe I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is online now
up and down cut spiral bits in hand held router vs table mounted router almost there Router Bits - Types and Usage 17 04-22-2014 11:00 AM
Newbie in using a Router..... Andron General Routing 6 03-20-2013 02:20 PM
New router and which starter router bits for my useage? Skyglider Router Bits - Types and Usage 11 12-08-2010 09:42 PM
How to buy router bits xplorx4 Router Bits - Types and Usage 31 02-09-2009 01:04 AM
