Ovolo Profile For External Door - Router Forums
post #1 of 3 (permalink) Old 04-15-2017, 05:16 AM Thread Starter
Gaia's Avatar
First Name: Peter
Default Ovolo Profile For External Door
Hi,
I'm looking for suitable 1/2" shank router cutter that can cut an ovolo quarter round profile of a suitable size. This would be to use as a base to carve egg and dart moulding on an external door curve, see attached screen shot.
Also what sort of dimensions would I be looking for in a suitable cutter, by dimensions I mean see other attached.
I assume I'm looking for an ovolo shaped cutter to use as a base to carve the egg and dart?
Thanks,
Peter.
Gaia is offline
post #2 of 3 (permalink) Old 04-15-2017, 12:12 PM
Here's a place to start looking Peter. If the profile is very small then it's more likely to come as a 1/4 shank bit. Freud Tools
post #3 of 3 (permalink) Old 04-15-2017, 01:41 PM
MEBCWD's Avatar
Originally Posted by Gaia View Post
Hi,
Thanks,
Peter.
You do need an ovolo cutter and dimensions will be determined by your project.
If you are doing this on a jewelry box top then the diameter and radius will be small to fit the thickness of the top.
If you are working on a large heavy mantle piece you maybe looking at 2 1/2" or larger diameter and you might want an oval profile for the radius portion of the bit instead of the round over type bit, depends your final design.
Remember you are in charge when it comes to design. It might not have to be a standard Egg and Dart it could have every other dart reversed or be a double egg and dart. This bit just cuts the stock quickly to get rid of the waste material.
MEBCWD is offline
Which Router Cutter For House Door Stile Edge Gaia Router Bits - Types and Usage 8 11-19-2015 03:50 PM
Profile Cutting Cutters and their Bearings neville9999 Jigs and Fixtures 7 12-10-2012 01:11 PM
Pattern routing to match cabinet door profile Rosenholm New Member Introductions 4 07-19-2012 05:42 PM
Profile Cutting Options BobCAD CAM aldepoalo CNC Routing 0 02-08-2012 10:49 AM
