T Track Channel - Router Forums
 4Likes
  • 1 Post By Stick486
  • 2 Post By MT Stringer
  • 1 Post By hawkeye10
post #1 of 6 (permalink) Old 05-02-2017, 02:34 PM Thread Starter
Default T Track Channel
I am making a jig which uses UJK Technology Universal T-Track, it is 19mm wide 9.5mm deep and the length after trimming will be about 700mm channel.
I propose to cut the channel using my Festool router with 1/2 collet and the Festool track which will be clamped to the workpiece.
The board I will use for the jig is a laminated plywood which I think is 18mm deep.
I expect I will need at least two passes to get to 9.5mm depth
I have two questions
1, What type of router bit should I use?
2, In which direction do I move? normally I would move the router away from me
Regards
John
John Charnock is offline
post #2 of 6 (permalink) Old 05-02-2017, 04:14 PM
Regards
John
1... plunge cut straight bit... (dia of your choice) and I like my Freud...
2... guide to the right - to you... left side - away from you.... top - to the right... bottom of the router - to the left...
jj777746 likes this.
post #3 of 6 (permalink) Old 05-02-2017, 05:56 PM
MT Stringer's Avatar
So, are you basically saying you need to cut a dado 19mm wide and 9.5mm deep?
If it were me, I would make a template out of 1/2 inch mdf. Then using a 1/2 inch pattern bit, run it around the inside of the template until you get the desired depth.
Check out my exact width dado jig. More info here --> http://www.routerforums.com/jigs-fix...-dado-jig.html
Hope you find this helpful.
Name:	2016-11-06 19.27.49.jpg
Name:	2016-11-06 19.25.00.jpg
Name:	2016-11-07 14.32.59.jpg
Name:	2014-12-08 17.46.13.jpg
TenGees and hawkeye10 like this.
MT Stringer is online now
post #4 of 6 (permalink) Old 05-03-2017, 12:25 PM
Hi, Mike's suggestion is probably your best bet, and about the easiest to manage. Make certain the edges are straight, and that the fixed piece is perfectly square to the side rails. I used to use a simple square for this, but they are not always exact 90 degrees. Buy a set of engineers squares when you want exact 90s, or a really high quality speed square for 90 and 45s.
You will place a piece of the material you are going to insert into the dado to set the width, but I found I needed to add a piece or two of paper in as well to allow for glue.
If you are gluing an edge piece of ply, I'd glue that edge first, then after a minute to let it soak in, I'd glue the dado and insert the piece. You'll only have a few seconds to position the piece to the edges, and be sure you have it set square to the piece with the Dado--that's what those clamp on corner braces are for (see pix).
Once that glue sets, what you set up is no longer adjustable.
Name:	brace corner.jpg
DesertRatTom is online now
post #5 of 6 (permalink) Old 05-03-2017, 05:06 PM
hawkeye10's Avatar
First Name: Don
Very good post Mike.
MT Stringer likes this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #6 of 6 (permalink) Old 05-04-2017, 01:32 AM Thread Starter
Good idea and worth thinking about, thanks
Triton Track Saw - and others? RickPr Tools and Woodworking 13 03-05-2016 08:47 AM
For Sale: Eagle-America Wooden Train & Track Kit Ray Newman Woodworking Classifieds 0 10-04-2015 03:42 PM
Anyone use a Festool track saw ? RainMan 2.0 Tools and Woodworking 39 07-03-2015 03:07 AM
Router miter slot vs track jetjocky New Member Introductions 10 01-24-2015 08:14 PM
A "closed-in" mitre track? matt1710 Table-mounted Routing 8 05-22-2011 06:27 AM
