Tongue and Groove width - Router Forums
 7Likes
post #1 of 13 (permalink) Old 05-16-2017, 09:15 AM Thread Starter
First Name: Neal
Default Tongue and Groove width
I have recently purchased a Freud Tongue and Groove router bit set. The bit set has a chart which shows how to achieve certain tongue and groove width by using the provided spacers. I have read that you are supposed to center the tongue on the board but I can’t find any information that tells me if my stock is ¾ inch, what size should my tongue and groove be. Is there a chart or some other method that I can use to determine how wide my tongue and groove should be for 3/4 inch stock or any other size stock?
nrudnick is offline
post #2 of 13 (permalink) Old 05-16-2017, 10:10 AM
vchiarelli's Avatar
First Name: Vince
Neal, I don't know of an actual chart, but generally speaking the tongue should be 1/3 of the material you are using, so for a 3/4" board, the tongue should be about 1/4".
BTW, welcome to the forum
vchiarelli is offline
post #3 of 13 (permalink) Old 05-16-2017, 10:46 AM
Nickp's Avatar
First Name: Nick
Neal...welcome to the forum...
As Vince responded, 1/3 of the width is a good rule of thumb or as required by your application or as dictated by the groove bit.
BTW...depending on the direction of the grain of the cuts and the application you are T&G'ing for, it could be possible that you might create a weak joint. For example, if you were T&G'ing for a table breadboard, you could be creating a weak joint on the long grain side.
One thing you might consider, for those joints needing lots of strength, would be to use a spline instead. You would cut a slot on both sides and use a floating spline essentially doing the same thing as a T&G except you would be able to put in a spline with grain perpendicular to the slots...mucho stronger... This also saves you some wood...the amount you would have cut off creating the tongue...
This is offered as an option...there are members who have been more than satisfied with T&G and others who are equally satisfied with just gluing the edges together...lots of experiences available on the forum using all these options...
Semipro and oldhudson49 like this.
Nick
Nickp is online now
post #4 of 13 (permalink) Old 05-16-2017, 10:42 PM
HI Neal and welcome. I also prefer splines to T & G. Splines lose no wood. T & G loses at least 1/4" . A spline is a free floating tongue in a double groove joint.
post #5 of 13 (permalink) Old 05-16-2017, 11:34 PM
what Cherryville and Nick said...
Ed3443 and jj777746 like this.
post #6 of 13 (permalink) Old 05-16-2017, 11:36 PM
sorry about the image posting failure...
just can't seem to get them to take...
Nickp likes this.
post #7 of 13 (permalink) Old 05-16-2017, 11:38 PM
another try...
Ed3443 likes this.
post #8 of 13 (permalink) Old 05-17-2017, 12:05 AM
try here to see the the attached pictures..
View Stick486's Uploads...
post #9 of 13 (permalink) Old 05-17-2017, 07:25 AM
oldhudson49's Avatar
First Name: Berry
The "1/3 rule" mentioned above, is what I've always followed....and welcome to the forum.
oldhudson49 is offline
post #10 of 13 (permalink) Old 05-17-2017, 08:14 AM
First Name: Richard
Welcome to the forum, Neal. Go with the spline.
Shop guy is offline
Tongue and groove tearout Mrs C Portable Routing 26 07-26-2016 12:32 AM
3/8 tongue & groove assembly bit johannmendelsohn Router Bits - Types and Usage 10 09-08-2014 01:46 PM
varying depth of Freud tongue & groove bits dicktill Router Bits - Types and Usage 7 06-04-2013 06:45 AM
Spline vs. Tongue & groove wanart General Routing 1 02-28-2006 06:22 AM
Tongue and groove bits archer_456 General Routing 4 02-18-2005 05:51 AM
