Am I crazy. - Router Forums
 7Likes
post #1 of 12 (permalink) Old 06-23-2017, 01:22 PM Thread Starter
Default Am I crazy.
I have a slight dilemma that I think my router might solve "IF" I can find the right bit(s) and I'm not crazy. I have a deck that needs some decking replaced. The new boards are slightly (maybe 1/16-1/8) too wide. I'm thinking that if I do a cut with a "rabbeting" bit that would take 1/16 of, then run a flush cut bit, I would trim 1/16. My question is, do they make such an animal? Working by myself so a router table isn't really and option on 16-18 ft boards and I don't have a place to store a router table if I buy one (yet).
I may be crazy thinking I can take such a small amount but thought I would ask.
PanelDeland is offline
post #2 of 12 (permalink) Old 06-23-2017, 02:00 PM
First Name: Clay
Well it could certainly be done with a router along the lines of what you are proposing. You could make a simple guide for your router and do it in one pass with the right bit. A table saw or circular saw would be much easier especially if you have very many boards.
kp91 and DaninVan like this.
fire65 is offline
post #3 of 12 (permalink) Old 06-23-2017, 02:13 PM
kp91's Avatar
First Name: Doug
You can play with different bearing and bit combinations and get almost any depth you want.
Most router bit sellers have replacement bearing kits for cheap
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #4 of 12 (permalink) Old 06-23-2017, 02:34 PM Thread Starter
I don't have a clue how to guide a 16-18 ft board by myself and be accurate enough is why I was considering a guided bit for both operations. I can clamp to a solid structure to do the routing but will have to check for a local source for bits.
post #5 of 12 (permalink) Old 06-23-2017, 03:11 PM
I'd be grabbing my circ. saw, and a rip guide. But with the guide on the opposite side of the saw, not as illustrated below...
(It'll work as shown below but you need another board for the base plate to ride on.)
fire65 and Job and Knock like this.
DaninVan is offline
post #6 of 12 (permalink) Old 06-23-2017, 04:42 PM
Terry Q's Avatar
I'd wait for the deck boards to dry out and shrink enough to put in place
Sent from my iPad using Tapatalk
Terry Q is offline
post #7 of 12 (permalink) Old 06-24-2017, 12:39 AM
Per Doug's suggestion you would want a rabbeting set something like this one: https://www.walmart.com/ip/Freud-Mul...&wl13=&veh=sem
post #8 of 12 (permalink) Old 06-24-2017, 09:13 AM
Garyk's Avatar
First Name: Gary
A simple (and temporary) job site router table can be made with two sawhorses, a piece of plywood, two by fours and some clamps. On the outfeed side of the 2x4 "fence" use a spacer to accommodate the cut off made by the router bit as the wood passes through the bit. A little bit of red neck engineering but it will work.
Garyk is offline
post #9 of 12 (permalink) Old 06-24-2017, 12:02 PM
Contributor of the Month
Bushwhacker's Avatar
First Name: David
I agree with both Dan and Fire65. I would consider using either the TS or finger ripping them with possibly sanding a round over on the upper edge when they are finished.
I have a 7 foot run out table on the end of my table saw but 16 and 18 foot boards would be still a bit long to control alone.
David
When the enemy is in range, so are you.
Bushwhacker is offline
post #10 of 12 (permalink) Old 06-24-2017, 03:16 PM
One other tool that is an option is a power planer. They'll take off 3/32 per pass so one to two passes will do it. They can be a very handy tool to have around because you often need to trim something to a wedge shape to fit (such as doors for example). A power planer makes quick work of that.
Am I Crazy? The Hobbyist Table-mounted Routing 71 07-16-2015 01:45 PM
Crazy cutting boards and Chess board Herb Stoops Show N' Tell 30 02-16-2015 06:26 PM
Not so crazy cutting boards and such xplorx4 Show N' Tell 18 12-02-2014 12:21 PM
Crazy cutting boards Chess board Herb Stoops Show N' Tell 7 11-23-2014 03:30 PM
A crazy idea? matt1710 Table-mounted Routing 15 10-03-2010 12:41 PM
