Cutting Cork - Router Forums
 2Likes
post #1 of 11 (permalink) Old 07-06-2017, 08:14 AM Thread Starter
rrrun's Avatar
First Name: Henry
Default Cutting Cork
My wife has been after me for years (think about that) to begin making coasters for sale at craft fairs, and I finally have figured out how to do that.
Almost.
My plan is to use my new CNC (OK, it'll be mine after I get it. For now, I'm just in fantasy land. Indulge me.) to route round holes in the coaster, which will be filled with cork that I will cut from sheets. The cork sheets will be either 1/8" or 1/4" thick.
What router bit should I use in the CNC to cut the cork?
rrrun is offline
post #2 of 11 (permalink) Old 07-06-2017, 10:02 AM
For cutting the cork circles I would try hollow punches first, especially if they are fairly small circles.
Semipro likes this.
post #3 of 11 (permalink) Old 07-06-2017, 06:40 PM Thread Starter
rrrun's Avatar
First Name: Henry
Not that small ... probably 4" circles. Maybe 4" rectangles with rounded edges.
Henry
Santa Clarita, CA
www.MowryJournal.com
rrrun is offline
post #4 of 11 (permalink) Old 07-06-2017, 07:30 PM
First Name: Earl
I've never had much luck cutting cork, except with sharp scissors. Quick search on the drone-powered shopping site and I found 1/8" thick 4" round cork at $12.99 for 24 (shipped), so it works out to $0.54 each. Cutting sheets may be cheaper on the surface, but I think i'd experiment with cutting methods before buying bulk sheets. Reading Charles' comment i'd bet on production pieces of cork being stamped.
Good luck!!
earl
greenacres2 is offline
post #5 of 11 (permalink) Old 07-06-2017, 07:36 PM
I think you might have to sandwich it between two sheets of something to cut it Henry. Or glue the cork to something stiffer first. I think I might try to find a 4" pipe or steel tube and sharpen the edge and turn it into a hollow punch.
post #6 of 11 (permalink) Old 07-07-2017, 07:24 AM
TwoSkies57's Avatar
a while back, I took a bunch of scraps and glued em up to make a few cutting boards and such.... then I thought to use the scraps from the scraps. Figured what the hell, make a few coasters with my grandson. 20 in total. just shy of 4"s in dia. 1/8"+ thick. Cork seemed to be the logical choice for the bottoms. I picked up some 12" x 12" x 1/8" squares from a local craft store. 4 to a pak. I forget the price, but remember it being reasonable enough.
Applied a liberal amount of spray adhesive to the cork (pretty sure it was 3M super 99) and let tack up. Laid out 5 coasters to a sheet. Sandwiched those sheets between 1/8" plywood. Then the whole package between a couple of 3/4" pieces of ply. Weighted down with a 30lp dumbbell and walked away for a few days. After I was sure everything had set and was dry, cut out the coasters with an scalpel (x-acto knife). Easy enough, nice clean cuts. Then took em over to the 12" disc sander, blended all the edges together then took some 180 and rounded over the bottoms. A few coats of spray on poly and a top coat of wax polish.
Cork will take a nice edge, but I don't think it'll hold up all that well. My experience with the stuff is that it wants to chip away. Rounding over the edges really seems to make a huge difference in terms of longevity. Im pretty sure you'd have the same issues when "stamping" out the cork unless you use some really sharp dies.
Skipper the Penguin
TwoSkies57 is offline
post #7 of 11 (permalink) Old 07-07-2017, 08:44 AM
hawkeye10's Avatar
First Name: Don
I have no idea how it would work but how about a scroll saw?
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #8 of 11 (permalink) Old 07-07-2017, 09:19 AM
MEBCWD's Avatar
Henry you should be able to cut it on a CNC using a sharp down cut bit using a jig to hold the cork. something like this. Run the toolpath, shift the cork in the clamp, run the toolpath, shift the cork .....
Name:	cork clamp.jpg
MEBCWD is offline
post #9 of 11 (permalink) Old 07-07-2017, 04:28 PM
First Name: Joe
Buy a laser cutter! LOL
Years ago, I made 100 sets (6 pieces plus a stand with four rounded dowels to hold them) I made these oak coasters for a Junior Achievement group. Used a forsner bit for the recess in 1/2" thick oak squares. We machined a hole saw into a "punch". The folks used a vise to punch out cork disks out of adhesive backed cork sheets. Came out nice!
tacomamactech is offline
post #10 of 11 (permalink) Old 07-08-2017, 03:15 AM
I was cutting some cork for an art project years ago, and after some tear-out, I started using my handy dandy X-acto knife and had nice clean cuts.
I like the idea of the cookie cutter/punch method, not sure if that would keep it clean, like if you had to twist your punch...
197761 is offline
Table saw long piece cutting jig Dejure Jigs and Fixtures 2 06-13-2016 11:54 AM
dado blade for spline joining sjonesphoto Tools and Woodworking 34 03-11-2014 11:11 AM
Cutting out Circles and Arcs the Easy Way learnexperience Portable Routing 1 11-26-2011 01:29 PM
New router and which starter router bits for my useage? Skyglider Router Bits - Types and Usage 11 12-08-2010 09:42 PM
