Acrylic Router Bit Question - Router Forums
 3Likes
  • 1 Post By Cherryville Chuck
  • 2 Post By Job and Knock
post #1 of 5 (permalink) Old 09-09-2017, 05:33 AM Thread Starter
First Name: Greg
Red face Acrylic Router Bit Question
HI Guys,
I have a small DIY project where I am making some cross cuts on 1" x 1" extruded acrylic rod. Before the cuts I need to make a centered 10mm square groove along the long axis of the rod.
This is such a small and simple project that I don't want to break the bank over expensive router bits and circular saw blade.
Would this bit be OK for my application?
https://www.amazon.com/Freud-MM-010-...uble+flute+bit
What type of saw blade would one recommend to cut acrylic?
Thanks Much!
G
apache67 is offline
post #2 of 5 (permalink) Old 09-09-2017, 10:42 AM
For a saw blade probably one with negative hook. For sure don't use one with a lot of positive hook. You can get bits for cutting plastic and the flutes are described as "O" flutes. Regular bits will cut the plastic but I've had them grab once in while and it usually knocks a chip out.
post #3 of 5 (permalink) Old 09-10-2017, 06:47 AM
bob817's Avatar
First Name: Bob (Robert)
My experienced Carpenter Brotherinlaw says to reverse your saw blade when ever cutting plastic this helps to reduce chip out please chime in my friends with your thoughts on this please.
bob817 is offline
post #4 of 5 (permalink) Old 09-10-2017, 09:40 AM
Reversing the blade would give it the negative hook I mentioned but it presents another risk. In normal operation the teeth on the blade are supported by the body from behind. When you reverse the blade all the pressure is on the welds so it is possible for the blade to lose teeth when you reverse it.
jj777746 likes this.
post #5 of 5 (permalink) Old 09-12-2017, 04:01 PM
First Name: Eric
I think that's pretty dumb because it will generate a lot of heat (friction) and then one thing you need to do when routing acrylic is to keep the temperatuers down - when it all gets hot swarf will just end up welding itself back onto the surfaces giving you that wonderful "shotblasted with rocks" look..... Use a fine tooth carbide sawblade with a zero or negative rake on the saw - for small quantities a jigsaw with a wavy set metal cutting blade works well but requires a bit more clean-up. For the router try to go to a spiral cutter. You don't need solid carbide on acrylic - HSS (which is far cheaper) will do and is what the industry used from the 1930s right up until the 1990s. Just keep the revs down and the feed speed up - the idea is to cut chips, not create "fuzz" - and use dust extraction if at all possibe because the airflow not only reduces weld-back, but also hepls keep it all cooler
billg71 and mikeskustomshop like this.
Job and Knock is offline
Newb. Question - broken router bit oilman87 Table-mounted Routing 23 05-19-2014 04:39 PM
Selecting the router bit for a given application Chris_L Router Bits - Types and Usage 4 02-13-2012 08:49 AM
Question about T-Slot Bit for router table fence. ryan.s Table-mounted Routing 5 05-02-2005 05:42 PM
