make picture frame - Router Forums
post #1 of 14 (permalink) Old 02-06-2009, 05:21 AM Thread Starter
Default make picture frame
I have a router table,router and table saw. I have very little experience
with routers. I only used my router to make My kitchen counters
a few years ago. I have been painting in oil for the last 10 years and
want to start selling them when I retire in two years,but I would like to
learn how to make the router profiles that I included in this post. If I could
make my own frame out of a $8 clear pine from home depot instead
spending $75 for the frame this would be a great savings. I don't
what I will used the router for later on, but for now frames are
a good start.
I'm not sure how to find these router bits or combine them to
make what I want. I plan on seeing if the library has any books on
routing,but any info would me appreciated. thanks tom
bytesnooper is offline
post #2 of 14 (permalink) Old 02-07-2009, 09:32 AM
derek willis's Avatar
First Name: Derek
Bytesnooper,
You will find it very difficult to realise the profiles you have described.
You would need to do this work on a router table, and use several bits to make up the profiles, although I say difficult it is easy on a table, get a catalogue of bits and look to how you could make up the profiles needed, take one pass to make the rebate, another pass to form the start of your profile and then yet another to finish off the shape needed.
Derek.
derek willis is offline
post #3 of 14 (permalink) Old 02-07-2009, 06:41 PM Thread Starter
Thank you for your respone. I bought a Bosch RA1181 Router Table. cant wait
to use it,but I need to study to understand your suggestions, like rebate etc.
I have only used the router I bought to trim a formica counter top. this is bigger
step to make a picture frame.
post #4 of 14 (permalink) Old 02-07-2009, 06:46 PM Thread Starter
anyone know of a good company router bit catalog i can request
thanks in advance
post #5 of 14 (permalink) Old 02-07-2009, 06:57 PM
HI bytesnooper
Here's two of many ,both are free,,,I just got the new sommerfeld one and and it's great it shows the price on the bits plus a picture of the profiles.. very nice catalog
http://www.sommerfeldtools.com/
http://www.mlcswoodworking.com/shops...cealedkits.htm
note
Below you will see a zip files with many bit profiles in the PDF format, it's a hard to find file,unzip it to a temp folder on the desktop then click on the PDF FILES
Note the picture frame pdf file in the zip file.. enjoy
http://www.thegrumble.com/showthread.php?t=22144
thanks in advance
post #6 of 14 (permalink) Old 02-08-2009, 06:01 AM Thread Starter
thanks bob,
Good amount of info to get started on.
post #7 of 14 (permalink) Old 02-08-2009, 06:29 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
The above advice is fine, however if you intend to make lots of picture frames, get what the professionals use, a guillotine which stamps out a "V" shaped piece leaving two perfectly clean accurate 45* corners. There are heaps of them on ebay, I have chosen this particular one because it's over here in Western Australia, but it shows you what I'm talking about.
http://cgi.ebay.com.au/Picture-Frame...QQcmdZViewItem
Harry
harrysin is offline
post #8 of 14 (permalink) Old 02-08-2009, 06:30 AM Thread Starter
Bob,
Are the picture frame profiles by woodmaster router bits or
knives for industrial planers ?
post #9 of 14 (permalink) Old 02-08-2009, 06:44 AM Thread Starter
Thanks harry,
The guillotine looks like it makes a real sharp 45 degree angle.
I will investigate further. If I frame all my paintings in the house.
I will need about 100 frames. 16x20 18x24 inch. When I retire in two
years and paint my landscape, seascape etc. painting full time I want
sell my paintings framed, so making frames is an ongoing project.
post #10 of 14 (permalink) Old 02-08-2009, 07:22 AM
dovetail_65's Avatar
First Name: Dovetail
Check this out. When I first received this book I did not think much of it. As I started to use and do more and more frames or framed objects of any kind, I found this book invaluable for visualizing and determining the lumbers rough and exact lenghts needed for a given picture size.
The book has pictures of what frame widths look like in comparison to the size of the total frame and picture size and list all the measurements you need for a frame size based on the size of the picture. If you have an 18" x 24" picture the inside measurement for the frame is simple to determine. But what if you were limited on lumber and wanted to know the outside measurement for say a 2" verse 5" frame.
The outside measurement of the frame is what dictates the length lumber you need and is dependent upon the frame width. This is all listed in an organized fashion with pictures of almost any sized picture you can think of.
Give it a try I think after you use it a few times you may like it too, this book is perfect for you bytesnooper since you are going to make so many frames:
http://www.in-lineindustries.com/pic...rame_book.html
dovetail_65 is offline
Picture frame router bit ryansdad323 Table-mounted Routing 7 01-31-2010 08:17 PM
picture frame techniques reds_21 Tools and Woodworking 15 06-30-2009 04:43 PM
Routing a basic rabbet for a picture frame artframer General Routing 62 09-04-2007 10:13 AM
Fold-Out picture frame help edbd1100 Tools and Woodworking 17 06-30-2006 09:52 PM
Picture frame molding reible General Routing 4 11-14-2004 07:22 PM
