WHich bit to use - Router Forums
post #1 of 6 (permalink) Old 12-21-2017, 11:09 AM Thread Starter
Default WHich bit to use
Hi - I want to create these letters in white with a rounded shoulder. They will be about 8-10" high. WHat is the best bit to use?
THanks!
Bernie Rubenzer is offline
post #2 of 6 (permalink) Old 12-21-2017, 12:15 PM
Hi Bernie and welcome. This is one possibility but they only go so small and the deciding factor on whether one would work for you is how much clearance is there between some of the "arms" in those letters. Industrial router bits-Ovolo router bits-CMT tools I think there might be similar ones for a Dremel that would be smaller but I would have to research that.
I'm assuming that you were doing these freehand by the way.
post #3 of 6 (permalink) Old 12-21-2017, 12:20 PM
Gaffboat's Avatar
First Name: Oliver
We need more info to answer your question, Bernie. Are you cutting them out and rounding the edges or are you carving them into a surface and wanting rounded edges? A simple round over bit will work well if you are cutting them out first. If you want inset (carved into the surface) letters you might be able to get the rounded shoulders with a round over groove bit or a point cutting round over bit.
As Charles said, I'm also assuming you doing these freehand.
Gaffboat is offline
post #4 of 6 (permalink) Old 12-22-2017, 07:40 AM Thread Starter
Hi! Yes, doing them freehand, cutting them out first. My concern is getting the shoulder on some of the narrow areas without breaking off. Any advice is appreciated!
Bernie
post #5 of 6 (permalink) Old 12-22-2017, 08:58 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Bernie
The signs in these two pdf's may give you some ideas. The top round-over face cutter would give a round-over but great care would be required to keep the bit at the same distance all the way around each letter.
File Type: pdf Routing a sign freehand by Harrysin.pdf (932.0 KB, 34 views)
Harry
harrysin is offline
post #6 of 6 (permalink) Old 12-22-2017, 11:34 AM
JOAT's Avatar
First Name: Theo
I have the feeling that is a dirty word. Shame on you.
JOAT is online now
spiral bit for cutting plywood calneva Router Bits - Types and Usage 11 09-28-2017 06:25 PM
Glue Joint Router bit Setup on stock pooch692000 Router Bits - Types and Usage 5 12-02-2016 05:32 PM
Craftsman 1-1/2HP 315.17491 router severe vibration with t&g bit danmancalif New Member Introductions 4 02-19-2014 11:41 PM
straight vs. mortise?, and what bit for cleaning non-flat surface? achoox4 Router Bits - Types and Usage 9 12-17-2012 06:53 AM
straight bit / spiral bit (solid carbide bit?) hyiu Router Bits - Types and Usage 3 04-13-2010 09:09 PM
