How do you open the Freud router bit package? - Page 2 - Router Forums
 70Likes
post #11 of 40 (permalink) Old 01-19-2018, 12:10 AM
hawkeye10's Avatar
First Name: Don
Hi Jenny and welcome. Be very careful and don't drop the bits. The carbide tips are very hard and that is good but they are brittle and break easely. You probably already know that but just incase you didn't you do now.
Steve57 likes this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #12 of 40 (permalink) Old 01-19-2018, 12:14 AM
I guess this rules out using a hammer... eh...
post #13 of 40 (permalink) Old 07-25-2018, 08:10 PM
papasombre's Avatar
Country: Venezuela
First Name: Alexis
I love this forum.
There are answers for almost everything!!!
kp91, JFPNCM, DesertRatTom and 1 others like this.
We, woodworkers are everywhere!!!
papasombre is offline
post #14 of 40 (permalink) Old 07-25-2018, 09:46 PM
Originally Posted by papasombre View Post
I love this forum.
Maybe not an answer to every question, but certainly no dearth of opinions.
Gene Howe, DaninVan and jj777746 like this.
post #15 of 40 (permalink) Old 07-26-2018, 02:36 PM
kp91's Avatar
First Name: Doug
Originally Posted by JennyMM View Post
Maybe dumb question, but this is HARD plastic with a hard plastic bottom. Says "pull", but not working! Tips? I also saw a post somewhere where the man couldn't remove the bit from the bottom part after he got it open. This is about 4 years old, don't think they make this packaging anymore. Help?
I agree that sometimes a 3 lb engineer's hammer is the most appropriate tool...… at least it makes me feel better.
https://en.wikipedia.org/wiki/Wrap_rage There's even a term for the frustration
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #16 of 40 (permalink) Old 07-27-2018, 05:33 PM
Hypnotoad's Avatar
First Name: Phillip
I have one of those Bosch router bit sets and the slots where the router bits fit into are that tight I need to wear gloves to get them in and out, you would think they would make them a little looser as you can easily cut yourself using bare fingers.
Tight fisted old so-and-so!
Hypnotoad is offline
post #17 of 40 (permalink) Old 07-27-2018, 07:00 PM
They're for display, Phill; you're not supposed to actually use them!
(You buy a cheap set for that...)
Gene Howe, jj777746 and Hypnotoad like this.
DaninVan is offline
post #18 of 40 (permalink) Old 07-28-2018, 07:35 AM
JOAT's Avatar
First Name: Theo
Nah, just nothing over a pound.
JOAT is offline
post #19 of 40 (permalink) Old 12-14-2018, 09:13 AM
First Name: Tony
If you turn the case over you'll see a small hole on the bottom. Put the case in a vice upside down and using a pin set and hammer lightly tap the bit until its almost out then remove it from the vice and pull the rest of the bit out by hand.
A Nose for Wood is offline
post #20 of 40 (permalink) Old 12-14-2018, 01:43 PM
Gene Howe's Avatar
First Name: Gene
I've considered TNT.
Gene Howe
Snowflake, AZ
Gene Howe is offline
Ridgid R2930 (fixed and plunge base routee) xplorx4 Tool Reviews 15 09-23-2014 09:15 AM
First Benchtop Router Table, get a plate or go bare? silentblackhat Table-mounted Routing 38 05-30-2012 03:30 AM
Two wrench method- one wrench router Delta6mike General Routing 68 03-26-2012 10:25 AM
Using Your Router For The First Time learnexperience General Routing 0 07-23-2011 10:20 PM
So you want to buy a router table... BobandRick Table-mounted Routing 39 08-30-2010 06:23 AM
