Impost Block Bit - Router Forums
 10Likes
post #1 of 14 (permalink) Old 01-20-2018, 07:28 PM Thread Starter
Steve57's Avatar
First Name: Steve
Default Impost Block Bit
Hi all, Iím new, hopefully finally in the right place. Iím building 3 walls of bookcases, and am using fluted molding with blocks to transition to the crown and base moldings. BMC/Smoot sells a small molding piece called ďSolid Pine Impost Block 883.Ē They are around $7 each, and I will need a lot of them, so Iíd like to try making them myself. Could anyone help me with finding a router bit for this? Thanks much!
Steve57 is offline
post #2 of 14 (permalink) Old 01-20-2018, 07:38 PM
is this it???
7/8" x 2-1/2" Solid Pine Impost Block SM880 | SM880 | Build With BMC
Steve57 likes this.
post #3 of 14 (permalink) Old 01-20-2018, 07:47 PM
MT Stringer's Avatar
@steve - I deleted your other post.
Welcome aboard. Lots of good folks here.
Steve57 likes this.
MT Stringer is offline
post #4 of 14 (permalink) Old 01-20-2018, 08:01 PM Thread Starter
Steve57's Avatar
First Name: Steve
Hey Thanks!
is this it???
Thanks very much! I donít have enough posts for a photo or url, so I appreciate you checking it out! Yes, thatís the profile.
Steve57 is offline
post #5 of 14 (permalink) Old 01-20-2018, 08:07 PM
old55's Avatar
First Name: Ross
Welcome to the forum Steve.
Steve57 likes this.
Ross,
ĎMembers are requested to add a first name in their profile as we are a very friendly bunch here'.
old55 is offline
post #6 of 14 (permalink) Old 01-20-2018, 08:29 PM
I couldn't find that exact profile, but you could do it with 2 set-ups with a cove bit and a beading bit. Would take some setting up,don't know if it would be worth it. You could make a similar profile with crown molding bits ,or picture framing bits for the face and glue it to a 45 degree chamfer to make a crown molding. Not sure if that is cost effective either.
Steve57 likes this.
Herb Stoops is online now
post #7 of 14 (permalink) Old 01-20-2018, 09:02 PM
you could do that as built up (3 pieces) but the total cost of bits may hurt your brain...
do you have a router table??? if not, stop where you are...
you need to cut a cove..
Freud Tools | 3/4" Radius Cove Bit
the bull nose/half round...
Freud Tools - Search Results for half round
then the kanted/chamfered base...
Freud Tools | 7/8" (Dia.) Chamfer Bit
that's 3 pieces, each w/ it's own profile stacked (built up) on top of each other...
post #8 of 14 (permalink) Old 01-20-2018, 09:39 PM Thread Starter
Steve57's Avatar
First Name: Steve
you need to cut a cove..that's 3 pieces, each w/ it's own profile stacked (built up) on top of each other...
Thanks much both of you! I have a router table. I have the cove bit, and will look for the round/bead tomorrow and give it a try. Youíre right at some point itís not cost effective. She has decided it must be that profile, so Iíll see what I can do before I have to admit defeat and sign my next paycheck over to Smoot.
Steve57 is offline
post #9 of 14 (permalink) Old 01-20-2018, 09:42 PM Thread Starter
Steve57's Avatar
First Name: Steve
Thanks Ross!
Steve57 is offline
post #10 of 14 (permalink) Old 01-20-2018, 09:46 PM
hawkeye10's Avatar
First Name: Don
Great post Stick. That is what I call helping someone out.
Stick486 and Steve57 like this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
Fingerboard sanding block radius fixture difalkner Jigs and Fixtures 6 04-26-2016 09:36 PM
For Sale: Whiteside 3390 Fine Finger Joint Router Bit jvg2259 Woodworking Classifieds 4 07-02-2015 09:31 AM
3/4in Depth cut rabbeting bit Rell Router Bits - Types and Usage 5 01-20-2012 11:16 AM
Bit sets - deal or not ? dietz Router Bits - Types and Usage 5 12-27-2004 06:50 PM
