Novice needs advice
3K views 13 replies 11 participants last post by  gjackson52
Hi experts,
I want to reproduce the corner detail on the posts in the attached photo. The corner edges have some sort of groove that I assume was made with a router. I just don't know what bit I would use to reproduce it. Any ideas would be welcome.
And sorry I don't have a close-up of the detail. This photo is the best I can do.
Thanks!
It looks like a cove profile to me too. Either the round nose bit Stick suggested or a cove bit like this: https://www.amazon.ca/Freud-30-114-2-Inch-Radius-Router/dp/B00004T7F3 If you use the round nose bit you'll need to have an edge guide attached to the router. The cove bit has a bearing that will guide it. Both come in a variety of sizes as does the round over bit. Just guessing from the look of those posts I would say the 1/2" radius should be close.
Looks like a roundover bit to me, but I think it was done on a router table with either a stop block or a mark on the fence to mark the starting and ending point. If it was done in the field, someone was being careful to start and stop the cut near about 6 inches from the end. But I'd bet on a table being used on the ends. So much easier to do that way. If I were the contractor I'd do these in a shop and bring it to the site ready to go. On a table it'd be done in a few minutes. Attractive look.
#13 ·
Tom I regularly do stuff like that handheld. You just do a rough calculation of the offset from the outside edge of the base to the bit and then mark where you want the base to stop on the piece. If it's off even an 1/8 of an inch no one would ever notice.
