Undersized ply router bits. - Router Forums
 39Likes
post #1 of 20 (permalink) Old 04-14-2018, 10:12 AM Thread Starter
hawkeye10's Avatar
First Name: Don
Default Undersized ply router bits.
A while back I ordered a three pack of undersized ply router bits. The brand is Whiteside and the part # 470. These bits are undersized alright, they are too small and too big. The 1/4" bit is 7/32 and my Baltic birch ply will not fit into the grove. The 1/2" bit is 31/64 and the Baltic birch ply fits loose. The 3/4" bits fits better than the others but in my opinion, it should fit snug.
So what gives here?
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #2 of 20 (permalink) Old 04-14-2018, 11:57 AM
The problem is that I'm not sure there is a standard for finished ply. It starts out rough and then it gets sanded smooth. That's why it winds up under size. To make matters worse a lot of what I've seen lately is metric thickness to start with I think. Your best bet is probably to use an smaller bit and go with one of the exact thickness jigs that have been posted.
Danman1957, TenGees, rrrun and 3 others like this.
post #3 of 20 (permalink) Old 04-14-2018, 12:12 PM Thread Starter
hawkeye10's Avatar
First Name: Don
Charles that is what I was thinking of. The bad part is I spent $52 for the 3 bits and now I don't need them.
Someone got my money tree this winter. I may be wrong but it might be Theo that got it.
Just kidding Theo.
post #4 of 20 (permalink) Old 04-14-2018, 03:00 PM
I have three undersized 3/4" bits, all cut slightly different width grooves. I have an 18 mm bit that I bought to use with the Sande plywood that I use a lot, sometimes the plywood doesn't fit the groove. I now have a block with four dadoes cut across it, identified to the bit used, and use it to check for the required fit with the actual plywood that I'm using. If none of them give me that fit that I'm looking for, it's time for a 1/2" bit and an exact-fit jig.
tomp913 is offline
post #5 of 20 (permalink) Old 04-14-2018, 03:47 PM
undersized bits come in imperial and metric...
all slightly different sized...
jj777746 likes this.
Stick486 is offline
post #6 of 20 (permalink) Old 04-14-2018, 07:37 PM
TWheels's Avatar
Amana sells a large variety of sizes. However, their "metric" bits are in fact Imperial approximations.
https://www.toolstoday.com/straight-...roduction.html
https://www.toolstoday.com/undersize...uter-bits.html https://www.toolstoday.com/straight-...roduction.html
For true metric sized bits, checkn Freud or CMT
I Hope to Be the Person My Poodles Believe I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is offline
post #7 of 20 (permalink) Old 04-14-2018, 07:44 PM
And plywood isn't necessarily consistent in thickness across or along a sheet. I was cutting dados for plywood recently and with the same dado setup, some pieces of the plywood fit, and others didn't. They were all cut from the same sheet!
I cut my dados a little wide to allow for such, and for wood expansion due to soaking up the glue.
gn86 likes this.
<Chas>
I'll burn that bridge when I come to it
CharlesWebster is offline
post #8 of 20 (permalink) Old 04-14-2018, 07:59 PM
very true for imported plywood due to poor QC...
Ray Newman and DesertRatTom like this.
Stick486 is offline
post #9 of 20 (permalink) Old 04-14-2018, 10:07 PM
true even for the local plywood produced here in the PNW! And don't dado on a dry day and try to assemble on a wet one ;-)
<Chas>
post #10 of 20 (permalink) Old 04-14-2018, 10:24 PM
JOAT's Avatar
First Name: Theo
Just kidding Theo.
Sure wasn't me, I'd have been bragging about it if so.
I work mainly with 1/2" plywood. The few times I need to cut a slot to fit plywood into it, I usually tack a strip to rout a straight line, then mark how wide I want it to be, tack down a strip, and rout that side. So far that gives me just the widths I want, with a snug fit. Used to do a lot of that when I was making my small figure banks. Best I can come up with, because that's the way I do it, it works for me, and not likely to change. I tack everything down, I don't worry about nail holes, because I make sure they will be hidden when whatever is put together. No need to replace tape when it runs out either, a box of nails should last me forever.
JFPNCM and hawkeye10 like this.
JOAT is online now
Sort Members by City or Zip RJM60 Site Help and Suggestions 56 03-13-2014 05:40 PM
How to buy router bits xplorx4 Router Bits - Types and Usage 31 02-09-2009 01:04 AM
