Which router bit? - Router Forums
 6Likes
post #1 of 15 (permalink) Old 04-23-2018, 09:18 AM Thread Starter
Weh2k9's Avatar
First Name: Jacob
Default Which router bit?
I'm looking to create this simple board game with my router that holds marbles. What router bit be most suitable for making this half sphere type cut with a plunge router ?
Weh2k9 is offline
post #2 of 15 (permalink) Old 04-23-2018, 09:26 AM
ball/round nose bit....
Freud Tools - Search Results for round nose
post #3 of 15 (permalink) Old 04-23-2018, 10:20 AM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Thats a hell of a job with a plunge router, do you not have a drill press?
DaninVan and Shop guy like this.
sunnybob is offline
post #4 of 15 (permalink) Old 04-23-2018, 11:36 AM
DonkeyHody's Avatar
First Name: Andy
Plus one for the drill press. Getting the router bit centered in just the right spot so many times seems a daunting task. Chuck up a ball-nose bit in your drill press and run it at top speed.
Shop guy likes this.
DonkeyHody is offline
post #5 of 15 (permalink) Old 04-23-2018, 12:48 PM
If you are going to do this with a router, make a template on the drill press and then use a bushing on the router to cut the board.
If you are doing only one ,just use the drill press with the router bit. You might want to dimple the hole first with a small drill bit to act like a pilot to keep the ball bit from wandering on the drill press. Also putting the drill press on highest speed with the router bit.
Herb Stoops is online now
post #6 of 15 (permalink) Old 04-24-2018, 08:52 AM
First Name: Gary
I was going to make a Chinese checker board once, but found that the post on my drill press would not allow me to reach far enough. I would have to make a template and use a plunge router with a guide bushing to accomplish it. I never made it sorry to say.
gmercer_48083 is offline
post #7 of 15 (permalink) Old 04-24-2018, 09:30 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
This pdf shows how I made a game of solitaire.
File Type: pdf Solitaire marble game based on a design by Santè.pdf (3.20 MB, 78 views)
Harry
harrysin is offline
post #8 of 15 (permalink) Old 04-24-2018, 07:17 PM
Red Stick's Avatar
First Name: Keith
Check Rockler.com. They sell a package of 60 marbles for Chinese Checkers and a router bit specifically to accommodate them.
Red Stick is offline
post #9 of 15 (permalink) Old 04-25-2018, 05:57 AM Thread Starter
Weh2k9's Avatar
First Name: Jacob
I have a triton m0f001 what sort of bush would I get for this to achieve what I'm looking to do. I'm completely new to routers and the techniques involved to do different things.
Weh2k9 is offline
post #10 of 15 (permalink) Old 04-25-2018, 06:12 AM
since you say that...
here's some reading that may help you out...
File Type: pdf R5 Climb-Cutting Versus Chip-Cutting.pdf (176.1 KB, 21 views)
File Type: pdf Routing for Beginners - Lesson - 3.pdf (856.1 KB, 17 views)
Stuck Router Bit Noj Router Bits - Types and Usage 11 07-21-2014 04:18 AM
