2 flute vs 3 flute spiral upcut - Router Forums
 10Likes
  • 2 Post By difalkner
  • 1 Post By Herb Stoops
  • 3 Post By Cherryville Chuck
  • 3 Post By MEBCWD
  • 1 Post By Flipsaw
post #1 of 7 (permalink) Old 04-24-2018, 09:13 PM Thread Starter
First Name: JJ
Default 2 flute vs 3 flute spiral upcut
Wanted to get some opinions. Looking at Whiteside Carbide 1/2" x 2" bit and there is only a $3 difference in the price.
Thanks in advance.
Flipsaw is offline
post #2 of 7 (permalink) Old 04-24-2018, 09:29 PM
difalkner's Avatar
First Name: David
What material are you cutting, are you cutting by hand or CNC, are you looking for a finishing cut or roughing out, what's the bit speed, etc.?
I would use the 3 flute for a finishing cut and the 2 flute for general purpose and roughing out. But then, I also use the 2 flute for my finishing cuts on the CNC most of the time.
David
radios and Flipsaw like this.
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #3 of 7 (permalink) Old 04-24-2018, 09:40 PM Thread Starter
First Name: JJ
Will most likely be using with MDF with a Freud Plunge Router to make a table top similar to a MFT top. Just received Woodpeckers Hole Boring Jig . BTW the router has a 22,000rpm speed.
Flipsaw is offline
post #4 of 7 (permalink) Old 04-25-2018, 12:08 AM
You can dial in the speed of the cutter by the sound. Start at a low setting and increase to where it sounds good. You will know if it is too fast, it will send chills down your spine and dial it down a little until it is nice and smooth sounding.
I like 3 or 4 flute bits, they cut so nice and smooth.
Flipsaw likes this.
Herb Stoops is online now
post #5 of 7 (permalink) Old 04-25-2018, 08:00 AM
You can get single flute spirals too. Fewer flutes cut faster but leave a poorer finish. Any bit that small a diameter can be run full speed (up to about 1.5”) but that not give you the best results. Fewer teeth on a table saw blade work the same way finish wise.
radios, Herb Stoops and Flipsaw like this.
post #6 of 7 (permalink) Old 04-25-2018, 12:03 PM
MEBCWD's Avatar
The 3 flute bit will remove around 1.5 times as much material as the 2 flute bit so the feed rates should be faster or the spindle speeds should be slower to keep the bit from building up heat that could cause the cutting edge to dull faster. Best to check the manufacturer's specs and go from there to git the best performance and life from the bit.
difalkner, vchiarelli and Flipsaw like this.
MEBCWD is offline
post #7 of 7 (permalink) Old 04-25-2018, 02:04 PM Thread Starter
First Name: JJ
Thumbs up
Thank you to the members who gave their opinion . Thinking I will go with the 3 flute hoping that in the end I will get a better fit for bench dogs , etc.
Herb Stoops likes this.
Flipsaw is offline
Availability of Metric Spiral Upcut Bits in the US? williaty Router Bits - Types and Usage 13 01-13-2014 07:27 AM
for those who cant afford spiral upcut bits... Mike Gager General Routing 21 12-08-2012 04:00 PM
upcut vs downcut spiral Skyewalker Router Bits - Types and Usage 7 09-10-2012 05:00 AM
Spiral upcut twin flute mickleuk Router Bits - Types and Usage 2 04-16-2011 03:16 PM
upward spiral bits VS 2 flute straight bits 911mickeyh Router Bits - Types and Usage 27 01-09-2010 01:53 PM
