I purchased the Freud inlay template, but it came with a spiral up bit. I thought that you should only use a down bit for inlays? I inquired to their customer service and the told me that they send an up bit because no bits can break too easy. That sounds like crap to me... should I but a down bit?
The up spiral bit is going to give you the cleanest cut in solid wood. Down spiral bits are for cutting part way through laminates and veneer's. Compression bits are for through cuts in laminates and veneer's.
A spiral bit is cutting with a shearing action... like scissors or a paper cutter. You get a cleaner cut than with a straight bit. This will tend to tear out laminates or veneers but not solid wood.
For inlay I suggest using DOWN cut spirals all the time.
I do inlay everyday and the DOWN cut spiral is much better. The bit is only 1/8" to 1/4" most of the time and the dust collection will take the dust out. Such a little bit and shallow pocket does not create much heat in my experience.
The benefit to the down cut is it leaves the edges around the inlay pristine. An up cut bit tends to pull up the wood on the edges and you will need to sand, even in hardwood. After an inlay or two with the up cut bit you will be sanding every single pocket you make and if a big chip comes off the edge it is a hassle to fix.
The up cut really only excels for deeper pockets and mortises as the pockets are so deep for a mortise that you do need to direct the dust up and out. Any pocket for inlay over 9/16" to 1" deep is when I consider jumping to an up cut bit.
Another advantage is if I am routing to a pencil line free hand. The down cut bit is much better for me to get the router right up the the line. Using an up cut bit tends to push the edges up. You will find as you get closer to the pencil line more times than not with the up-cut bit it is much more difficult to get a nice cut at the line. It chips the wood at and into the pencil line more often and/or causes over cutting the line too. With the down cut router bit I can move the router and cut from the center of the pocket to the line, sneaking up on the line. With an up cut router bit I tend to have to work from the line to the center of the pocket and I don't like that.
This all really matters more on a shallow inlay than a deep recess for a sign, etc. For the deeper cuts the up cut bit benefits out weigh its drawbacks. You can also get a combination up/down or compression bit. For example I use the compression bit for going around the edges of a round floor inlay. I want the bottom ply edge to be cut cleanly and I also want the top hardwood edge to have a nice clean edge. The compression bit really works well for that.
These ideas are only my personal opinions and observations from doing the procedures.
Related Threads
747K posts
128.1K members
Since 2004
