Bits /Cutters for Exact Dado Cuts - Router Forums
 21Likes
post #1 of 16 (permalink) Old 05-23-2018, 07:57 PM Thread Starter
sreilly's Avatar
First Name: Steve
Default Bits /Cutters for Exact Dado Cuts
Well now I see cutters for dados and am wondering if it is better to make single passes for width or smaller bits and multiple passes. I'm guessing that using other wood than ply would require either planning the wood to exact thickness to fit the cutter or use smaller bits and make the passses needed to fit the wood. Any ideas? Better way to start?
i
sreilly is offline
post #2 of 16 (permalink) Old 05-23-2018, 08:05 PM
I like dual pass w/ a narrower bit than the finished dado or groove... no planing required usually...
makes for a cleaner cut...
MEBCWD and Herb Stoops like this.
post #3 of 16 (permalink) Old 05-23-2018, 09:00 PM
vchiarelli's Avatar
First Name: Vince
Using an "exact fit" dado jig, I use a smaller bit and make two passes. As stick says, makes for a cleaner cut.
Check out @MT Stringer uploads/posts for an exact fit jig, but there are a number of similar jigs on youtube.
vchiarelli is offline
post #4 of 16 (permalink) Old 05-23-2018, 09:37 PM
Members are finding that plywood thicknesses are so varied these days that exact thickness bits don’t always work so many are resorting to the 2 pass method.
MEBCWD, TenGees, Stick486 and 1 others like this.
post #5 of 16 (permalink) Old 05-23-2018, 11:44 PM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Its the dreaded metrification, creeping in by the back door. you'll be fine in another 20 years or so, once imperial has finally died out.
sunnybob is offline
post #6 of 16 (permalink) Old 05-24-2018, 11:03 AM
MEBCWD's Avatar
Actually I think the sizing in todays plywood is a lack of standards, poor manufacturing processes and no quality control. About 6 months ago I saw a load of plywood that was 1/8" difference in thickness from one side to the other. They were waiting on a truck to pick it up and return it to the distributor. The overseas manufacturer's machinery in a new plant was out of wack and no quality control lead to this plywood being sent all the way to a US store before anyone even noticed.
I know I have found large voids in some of the overseas plywood just by running my hand over the surface so I have been buying US made plywood , cost a little more but I don't have to deal with the voids.
Stick486 likes this.
MEBCWD is offline
post #7 of 16 (permalink) Old 05-24-2018, 11:23 AM
Originally Posted by MEBCWD View Post
1... Actually I think the sizing in today's plywood is a lack of standards, poor manufacturing processes and no quality control.
2... The overseas manufacturer's machinery in a new plant was out of wack and no quality control lead to this plywood being sent all the way to a US store before anyone even noticed.
3... I know I have found large voids in some of the overseas plywood just by running my hand over the surface so I have been buying US made plywood , cost a little more but I don't have to deal with the voids.
1... whole heartily agree...
2... they don't care.. we, the consumer, are their QC..
3... as long as this junk satisfies the wallet buyers.. it will continue to be dumped on us...
look how much FOD you can find in the plies of offshore plywood...
and we get their better junk if you can imagine that...
I like your support America stance... KUDOS...
refuse to buy it...
won't be long before things change...
look what happened to a few companies here as of late because they PO'd the American consumer...
accept garbage and you'll get more garbage.... stink and all...
the next counter body that tells you ''Well that is all there is'' jack slap 'em and shop elsewhere...
management will hear you loud and clear... money talks...
FOD: Foreign Object Debris (FOD) is any article or substance, alien to a product or system, which could potentially cause damage....
https://en.wikipedia.org/wiki/Foreign_object_damage
MEBCWD likes this.
post #8 of 16 (permalink) Old 05-24-2018, 12:01 PM
Go Harbor Freight!!!
Herb Stoops is online now
post #9 of 16 (permalink) Old 05-25-2018, 04:40 PM
First Name: Reuel
Default Undersized router bits for nominal 1/4" and norminal 1/2"
For the nominal 3/4" plywood (for shelves) it is feasible to do two passes using short 1/2" PATTERN BITS.
However for nominal 1/4" and nominal 1/2" plywood it is more feasible to use quality UNDERSIZED PLYWOOD DADO PLUNGE ROUTER BITS
e.g from AMANA
://www.toolstoday.com/undersized-plywood-dado-plunge-router-bits.html
CONDITION is you will need a PLUNGE ROUTER not a FIXED BASE ROUTER and a supplier of plywood with Standard dimensions.
Best Regards
Reuel
"The gift of God is eternal life thru Jesus Christ our Lord"
Reuel - means "God's friend" (Heb)
reuelt is offline
post #10 of 16 (permalink) Old 05-25-2018, 05:40 PM
First Name: Reuel
Default Cheap Chinese Undersized bits for DIY/handiman available
For about $15 from ebay.
Best Regards
Reuel
reuelt is offline
What about that newbie? 1fizgig New Member Introductions 45 03-18-2018 08:02 PM
Dado Jig for Plunge Router bobj3 Jigs and Fixtures 35 01-22-2010 01:01 PM
New user question for dado cuts with a router pb2375 Starting Off 6 07-13-2008 04:31 PM
Need help deciding on bits. ryan.s General Routing 8 03-25-2005 09:35 PM
