Best Bit for HDPE? - Router Forums
 5Likes
post #1 of 16 (permalink) Old 05-26-2018, 10:46 AM Thread Starter
Default Best Bit for HDPE?
Hello all,
For my business, I use Irwin (lowes) Crabide tipped roundover bit. I am repetitively routering 1/2" HDPE (plastic) and also using it on 1" and 1 1/2" schedule 40 PVC to make a smooth edge at the top. I am wondering if there is a better type or brand of bit that will last longer?
slyee07 is offline
post #2 of 16 (permalink) Old 05-26-2018, 11:16 AM
Hello and welcome N/A...
Freud or CMT negative rake bits...
clean often and use boeshield or dry lube such as TriFlow......
slyee07 likes this.
post #3 of 16 (permalink) Old 05-26-2018, 01:10 PM
Most bits are better than Irwin. For straight bits the ones for plastics have “O” flutes but I’m not aware of any profiles that are specially designed for plastic unless the ones Stick mentioned are. If you can get negative rake angle that’s important. Avoid any blade or bit with a positive rake angle.
post #4 of 16 (permalink) Old 05-26-2018, 05:44 PM
First Name: Reuel
Default Would pipe chamfering tools be useful
Originally Posted by slyee07 View Post
Hello all,
Would pipe chamfering tools powered by a cordless drill be useful too?
Works like pencil sharpeners.
Name:	pipe chamfering tool.jpg
aluminumwelder likes this.
Best Regards
Reuel
"The gift of God is eternal life thru Jesus Christ our Lord"
Reuel - means "God's friend" (Heb)
reuelt is offline
post #5 of 16 (permalink) Old 05-26-2018, 06:51 PM
I have several different types..
their primary usage is to chamfer the end of plastic pipe to make it easier for it to go into a cast iron pipe's hub adapter...
they don't radius... more of a straight taper...
they don't cut clean or uniformly especially if the cutter wobbles or is tipped a little......
did I mention they leave chatter marks???
post #6 of 16 (permalink) Old 05-26-2018, 10:43 PM
First Name: Reuel
Perhaps chamfer first and then round over with a router for a round-over finish.
It like making an octagon sectional blank with a bandsaw before sending the wood to a lathe for rounding.
Best Regards
Reuel
reuelt is offline
post #7 of 16 (permalink) Old 05-26-2018, 10:48 PM
the OP wanted better and correct tooling to speed up the operation while saving time, labor and money...
not add steps and tooling...
those pipe chamferers are some crude tooling but they perform just fine when used as intended...
slyee07 likes this.
post #8 of 16 (permalink) Old 05-27-2018, 06:32 AM
First Name: Reuel
Default plastic-cutting router bits
Some info on plastic-cutting router bits can be found:-
https://www.toolstoday.com/router-bi...uter-bits.html
Get the idea of the design as you can buy similar tools from other suppliers too.
Best Regards
Reuel
reuelt is offline
post #9 of 16 (permalink) Old 05-27-2018, 01:21 PM
TWheels's Avatar
I am not aware of any roundover bits designed specifically for plastics, and it is not for lack of trying. The bits referenced here much are more like bullnose or finger nail bits.
I Hope to Be the Person My Poodles Believe I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is offline
post #10 of 16 (permalink) Old 05-27-2018, 03:17 PM
First Name: Reuel
Two listed there are for PLASTIC edge rounding.
called: Solid Carbide Plastic 'O' Flute Router Bits for Edge Rounding
They do not look the same as the roundover bit (with bearings) designed for wood roundover.
https://www.toolstoday.com/solid-car...-rounding.html
Best Regards
Reuel
reuelt is offline
spiral bit for cutting plywood calneva Router Bits - Types and Usage 11 09-28-2017 06:25 PM
Glue Joint Router bit Setup on stock pooch692000 Router Bits - Types and Usage 5 12-02-2016 05:32 PM
Craftsman 1-1/2HP 315.17491 router severe vibration with t&g bit danmancalif New Member Introductions 4 02-19-2014 11:41 PM
straight vs. mortise?, and what bit for cleaning non-flat surface? achoox4 Router Bits - Types and Usage 9 12-17-2012 06:53 AM
straight bit / spiral bit (solid carbide bit?) hyiu Router Bits - Types and Usage 3 04-13-2010 09:09 PM
