Bit wear - Router Forums
 7Likes
  • 3 Post By Stick486
  • 1 Post By JOAT
  • 1 Post By Herb Stoops
  • 2 Post By DesertRatTom
post #1 of 8 (permalink) Old 05-30-2018, 02:46 PM Thread Starter
pusserboy's Avatar
First Name: Stuart
Default Bit wear
I've seen somewhere that using MDF will dull a bit faster than wood. If so how hard is MDF on the bits and should it be avoided.
Stuart
pusserboy is offline
post #2 of 8 (permalink) Old 05-30-2018, 02:56 PM
Stuart
it's not the hardness it's the abrasiveness...
IIRC there is about a 30 ~ 40% reduction in bit life...
economy bits don't last because of the softer carbide...
the dust is major detrimental to your health...
MDF is basically glorified particle board.
Just like particle board, MDF will soak up water and other liquids like a sponge and swell unless it’s very well sealed on all sides and edges with primer, paint, or another sealing product.
Because it consists of such fine particles, MDF doesn’t hold screws very well, and it’s very easy to strip the screw holes.
Because it’s so dense, MDF is very heavy. This can make it more difficult to work with, especially if you don’t have a helper who can help you lift and cut the large sheets.
MDF can’t be stained. Not only does it soak up stain like a sponge, but also because there’s no wood grain on MDF, it looks awful when it’s stained. (Kind of like staining particle board. Why would you bother?)
MDF contains VOCs (urea-formaldehyde). Off gassing can be greatly minimized (but probably not eliminated) if the MDF is encapsulated with primer, paint, etc., but care needs to be taken while cutting and sanding to avoid inhalation of the particles.
Barry747, thomas1389 and MYB506 like this.
post #3 of 8 (permalink) Old 05-30-2018, 02:58 PM
JOAT's Avatar
First Name: Theo
Can't tell you on that. I hate MDF, and don't use it. So, it doesn't wear my bits any at all.
But, bits will wear out, no matter what you use them on. Me, I just buy another bit when one wears out, and don't worry about it.
Herb Stoops likes this.
JOAT is online now
post #4 of 8 (permalink) Old 05-30-2018, 03:48 PM
Steven Owen's Avatar
First Name: Steven
I would think you could get 5-6 sharpenings out of a high quality bit. I’m surprised you’d be tossing any dull bits out.
I love to make pretty things for pretty little things
Steven Owen is offline
post #5 of 8 (permalink) Old 05-30-2018, 04:56 PM
Talk about dull bits, the original router HSS bits didn't last long, When they turned from blue to black they were over done , just toss them, when they cooled off.
thomas1389 likes this.
Herb Stoops is online now
post #6 of 8 (permalink) Old 05-30-2018, 08:32 PM
JOAT's Avatar
First Name: Theo
Possibly so, but there would be no money advantage to me by sharpening, I actually come out a bit ahead by buying new. Highly possible that this is so because I just use flush trim bits for about 99.99% of what I make. If I used different types of bits, this might not be so. Then there is the fact that I don't buy high quality bits, just decent quality carbide bits, at decent prices. Not sure how long I've been using my present bit, but it's been several years.
JOAT is online now
post #7 of 8 (permalink) Old 05-30-2018, 09:39 PM
I have a couple of small diamond sharpening cards that are for sharpening bits. The trick of sharpening is to make the cutter edge as square as possible. You don't sharpen the outside edge, that can alter the width and profile. You sharpen the flat, really its almost polishing, you're just reestablishing that edge, not grinding one. Note the Trend lubricant.
JIMMIEM and Bob Adams like this.
DesertRatTom is online now
post #8 of 8 (permalink) Old 05-31-2018, 09:19 AM Thread Starter
pusserboy's Avatar
First Name: Stuart
Thank you all gentlemen. Will take your advice.
Stuart
For Sale: Whiteside 3390 Fine Finger Joint Bit Jim Gallo Woodworking Classifieds 20 12-15-2016 08:59 PM
straight vs. mortise?, and what bit for cleaning non-flat surface? achoox4 Router Bits - Types and Usage 9 12-17-2012 06:53 AM
Router Bit Set for Raised Panel Doors Hoss McGr Table-mounted Routing 8 10-17-2009 04:17 PM
Router bits speedo Router Bits - Types and Usage 18 10-08-2009 03:17 PM
bit speeds, something to think about reible Router Bits - Types and Usage 0 10-19-2004 09:20 PM
