7mm round nose cutter - Router Forums
post #1 of 4 (permalink) Old 06-04-2018, 02:26 PM Thread Starter
Default 7mm round nose cutter
New here so apologies if this has been covered. I've searched high and low for a round nose cutter that has an outside cutting diameter of 5mm, 6mm, 7mm and 8mm. Any shank size. This is for a niche protoype hence the weird metric requirments. Do they exist??! Thanks in advance
breageside is offline
post #2 of 4 (permalink) Old 06-04-2018, 02:55 PM
mjadams61's Avatar
First Name: Marlin
If you are talking about something like this then check for METRIC Ball Nose End Mill. They are for metal but should beable to use for wood or for what ever.
https://www.redlinetools.com/CatSear...EaAleNEALw_wcB
mjadams61 is offline
post #3 of 4 (permalink) Old 06-04-2018, 03:58 PM
Amanda has some. Onsrud May also but the shafts are likely the same diameter on most of theirs.
post #4 of 4 (permalink) Old 06-04-2018, 06:07 PM
First Name: Reuel
a Kit
https://www.amazon.com/Wokesi-12mmBl...s=5mm+end+mill
add 7mm
https://www.amazon.com/Dormer-S5117-...70_&dpSrc=srch
Best Regards
Reuel
"The gift of God is eternal life thru Jesus Christ our Lord"
Reuel - means "God's friend" (Heb)
reuelt is offline
router bit question johnvmc CNC Routing 2 02-14-2016 01:52 PM
Round nose or Ball Nose Sebashtion Houston CNC Routing 6 12-12-2015 01:03 AM
Profile Cutting Cutters and their Bearings neville9999 Jigs and Fixtures 7 12-10-2012 01:11 PM
The use of a Router table as a Profile Copier neville9999 Jigs and Fixtures 4 12-06-2012 11:44 AM
Sign Making: Round Nose Bits newmexico Sign Creation 3 08-16-2012 04:02 PM
