identify router bit - Router Forums
 8Likes
  • 7 Post By Stick486
  • 1 Post By Stick486
post #1 of 8 (permalink) Old 07-12-2018, 03:15 PM Thread Starter
bugsy57's Avatar
First Name: ERWIN
Default identify router bit
I hope someone can identify this router bit i pulled from an old craftsman router. in case the pics arent clear it is round with spiral groves
Name:	2018-07-12 15-09-39.188.jpg
Name:	2018-07-12 15-07-40.559.jpg
Name:	2018-07-12 15-07-13.101.jpg
Name:	2018-07-12 15-06-58.110.jpg
Being depressed is no fun i should know because i had fun once!
bugsy57 is offline
post #2 of 8 (permalink) Old 07-12-2018, 03:24 PM
that's not a router bit..
it's a rotary burr...
DO NOT use it in your router....
burrs are used in Micro Motors, Pendant Drills, Flexible Shafts, and hobby rotary tools such as a Dremel.....
post #3 of 8 (permalink) Old 07-12-2018, 03:50 PM Thread Starter
bugsy57's Avatar
First Name: ERWIN
wow no wonder it took me a weeks worth of PB Blaster and a lot of tugging to get it out of the old craftsman router i found it in.
bugsy57 is offline
post #4 of 8 (permalink) Old 07-12-2018, 04:01 PM
it wasn't stuck because it was burr but because it was left in the router for who knows how long...
roxanne562001 likes this.
post #5 of 8 (permalink) Old 07-13-2018, 07:29 AM
sreilly's Avatar
First Name: Steve
That was my first thought, had to be a deburrer. Amazing what can be found.........I can't imaging that being used at those high speeds. Maybe we should try some small grinding wheels next.
sreilly is offline
post #6 of 8 (permalink) Old 07-13-2018, 08:19 AM
Country: South Africa
First Name: Hentie
I have those for using in a straight grinder (and some for other rotaries) , but for interest sake, why not use it in a router?
lowracer is offline
post #7 of 8 (permalink) Old 07-13-2018, 08:39 AM
what's the RPM of your die grinder???
that style of bur is intended for low speed use and using them in high speed tools is out of the their design parameters...
high speed burrs get pretty pricey...
post #8 of 8 (permalink) Old 07-13-2018, 08:46 AM
roxanne562001's Avatar
First Name: Roxanne
Like Stick said Rotary Burr. You use them in a die grinder for tool and die making. We used them for porting and polishing cylinder heads and intake manifolds at a machine shop I used to work at.
roxanne562001 is offline
Stuck Router Bit Noj Router Bits - Types and Usage 11 07-21-2014 04:18 AM
